Hi Adrianlm,DS-5 Streamline is the supported tool for profiling Mali T6xx devices. Currently we do not offer any other tool for this purpose.Thanks,Chris
Hi ,I'm stuck with mali400 platform. i have ddk release r2p4 is it possible to profile the GPU with this release? do i need to move to r3p2?on r2p4 i only get the linux and cpu traces no GPU traces and my silicon vendor ( hardkernel/samsung) is not releasing yet the r3p2 ( samsung still has to deliver it)any way to get the figures of the gpu usage ?Thanks
Hi ,I'm stuck with mali400 platform. i have ddk release r2p4 is it possible to profile the GPU with this release? do i need to move to r3p2?on r2p4 i only get the linux and cpu traces no GPU traces and my silicon vendor ( hardkernel/samsung) is not releasing yet the r3p2 ( samsung still has to deliver it)any way to get the figures of the gpu usage ?Thanks[size=2]
[/size]Hello nfstry,In addition to my previous response, you can get 'some' features of streamline working with just the kernel patches applied.So it depends on what kind of features you are after, which will dictate whether just applying kernel side patches will be sufficient.If you are interested in this, please let us know, and we can look into the best way to provide the appropriate kernel side patches for your device.- McGeagh
Hello McGeagh,That's a very good news. in fact we have a multilayer UI on android and we try to see the smoothness of the ui. we are comapring the same application on different GPUs ( mainly adreno vivante and mali) it seems that the adreno gives better results than the mp400 on this test., that's why we want to see if the overload happens on the gpu or not and if it is the case what's the bottlneck (cache misses or mem bandwidth or simply architectural issue ex : not supporting overlays) so any information which can help is more than welcome.Thanks
[ 1637.498392] gator: mali online _mali_profiling_set_event symbol not found[ 1637.507603] gator: mali online _mali_osk_fb_control_set symbol not found[ 1637.512948] gator: mali online _mali_profiling_control symbol not found
Hi McGeagh,I'm having very similar problem too. I'm using an Origen Quad board which uses Samsung Exynos 4 with Mali-400MP GPU. The GPU driver provided by Samsung is pretty old (r2p4). At first I cannot build the gator module for Streamline GPU profiling because there is no "mali_linux_trace.h" in the Mali driver folder. Then I copied the file with the same name from a newer version to the driver folder. I could build and run it, but I cannot get GPU profiling. Instead I get these error message:[ 1637.498392] gator: mali online _mali_profiling_set_event symbol not found[ 1637.507603] gator: mali online _mali_osk_fb_control_set symbol not found[ 1637.512948] gator: mali online _mali_profiling_control symbol not found [size="2"]Is there any work around for this problem other than asking Samsung for a newer version of Mali driver? Thanks.[/size]
Hi caogao,As we do not support r2p4 drivers for GPU profiling, we cannot help with this.For official support, you would need to ask Samsung for updated drivers.I apologise we cannot help you further on this.McGeagh
