Good morning.
I am looking for User Space Driver for X11 of Mali-450.
But I looked but only fbdev and wayland exist and x11 is not found.
I use a board called "ODROID-C1" (ODROID-C1 board uses Mali-450).This board provides the Mali User Space Driver for x11 at "github.com/.../mali_libs".But I could not find the X11 User Space Driver
The ODROID-C1 board manufacturer is "provided by ARM." It is called.Where can I find the User Space Driver for the Mali-450 to X11?
Hi, We are only able to directly provide a small number of reference drivers for a small number of boards on the Mali Developer portal. The official route for drivers is via the chipset manufacturer and/or device manufacturer for each device. There are literally thousands of chipsets and devices produced using our GPUs every year, and it is simply impossible for us to directly provide pre-tested drivers for every combination of board, operating system, and windowing environment. HTH, Pete
