Hi
i was trying to debug my game with mali debugger on android i followed step by step this post https://www.mcvuk.com/how-to-use-arms-mali-graphics-debugger-in-unity/but nothing show up on the debugger .
Hello Finder,This issue sounds a bit like the socket permissions issue on the FAQ. Can you try rebuilding the app as described in the FAQ?If that doesn't work, are you able to record and share the Android logcat output when you try to launch your application while connected to MGD?Thanks,Liam
