Hello everyone,
I am trying to set up the MPU in my LPC1769 Xpresso board. The memory map of LPC1769 is as given below:
512kB FLASH @ 0x0000 0000 – 0x0007 FFFF 32kB on-chip SRAM @ 0x1000 0000 – 0x1000 7FFFF
I am only configuring 2 regions.
/* Configure region 0 to cover 512KB Flash (Normal, Non-Shared, Executable, Read-only) */
MPU->RBAR = 0x00000000 | REGION_Valid | 0; MPU->RASR = REGION_Enabled | NORMAL | REGION_512K | FULL_ACCESS;
/* Configure region 1 to cover CPU 32KB SRAM (Normal, Non-Shared, NonExecutable, Full Access) */ MPU->RBAR = 0x10000000 | REGION_Valid | 1; MPU->RASR = REGION_Enabled | NOT_EXEC | NORMAL | REGION_32K|FULL_ACCESS; //#define REGION_32K (14 << 1)
The problem is that I am unable to decrease the region 1(SRAM) memory from 32K to a lesser value like 1K. Whenever I try to do so it gives Memory Management fault.
What could be the reason for this?
