Using the GICv2, software can change the CPU interfaces targeted by an interrupt (more precisely, an SPI) by writing to the corresponding GICD_ITARGETSR. The GICv2 specification states, in the paragraph "The effect of changes to an GICD_ITARGETSR" (page 4-108 in ARM IHI 0048B.b), that "[t]here is a small but finite time required for any change to take effect".
I am concerned by this sentence. After a write to GICD_ITARGETSR that removes a CPU from the targets, what does software need to do to wait until it is certain that said CPU will not acknowledge this SPI any more? (The specification is unclear to me; I cannot even answer this question in the simple case where the CPU making the write is the same as the one being removed from the targets.)
I believe you can simply poll the written GICD_ITARGETSR register until it reads back the expected value.
Thank you for your answer.
Can you confirm that the solution you suggest always works, or is it a possible interpretation of the specification? I thought about this solution as well, but nothing in the specification explicitly says that the effect "the SPI will only trigger on the newly targeted CPUs" must take place before the effect "reading back ITARGETSR returns the value that was last written".
Besides, if the IRQ is active and pending, then, according to the specification, the write "does not change the interrupt targets until the active status is cleared." So, if the IRQ is active on the same CPU that writes to ITARGETSR, polling ITARGETSR until its value changes might result in a deadlock. Anyway, this is just a possible interpretation of the specification.
