I have a source file, converted it to assembly and added 2 instructions and generated the final elf. When I load this final elf, symbols doesnt match the source due to assembly instructions addition.
Is there a way to align them ? am using ARM cortex-M4 and cortex-M0. I have tried to edit #line in assembly file to make sure lines match with source code but that doesn't give a good alignment. Any ideas?
please give us the concrete source code and dis-assembly code of the elf?
Best regards,
Yasuhiko Koumoto.
Source file: test3.c
Modified assembly is test3_qcm.S
Output : final.elf
commands I am using to generate the output
REM C:\Apps\ARMCT5.05\106\bin\armcc.exe --thumb --cpu Cortex-M4 -DT_ARM -D__ARMEL__ -D__RVCT__ --apcs /noswst/interwork --littleend --force_new_nothrow -g --dwarf2 -Otime -O1 -c -S -o test3.S test3.c
REM modify the file
C:\Apps\ARMCT5.05\106\bin\armasm.exe --cpu Cortex-M4 --apcs /noswst/interwork -g --dwarf2 test3_qcm.S -o test3.o
C:\Apps\ARMCT5.05\106\bin\armlink.exe --elf --map --info sizes,totals --list test3.map --symbols --symdefs test3.sym test3.o -o final.elf
test3.c
Modified assembly test3_qcm.S
; generated by Component: ARM Compiler 5.05 update 1 (build 106) Tool: armcc [4d0efa]
; commandline armcc [--thumb --dwarf2 --debug -c -S -otest3.S --cpu=Cortex-M4 --apcs=/noswst/interwork -O1 -Otime --sitelicense -DT_ARM -D__ARMEL__ -D__RVCT__ --force_new_nothrow test3.c]
THUMB
REQUIRE8
PRESERVE8
AREA ||.text||, CODE, READONLY, ALIGN=2
REQUIRE _printf_percent
REQUIRE _printf_d
REQUIRE _printf_int_dec
foo2 PROC
PUSH {R0}
POP {R0}
#line 5 "test3.c"
ADR r0,|L0.60|
B.W __2printf
#line 9 "test3.c"
ENDP
foo1 PROC
#line 12 "test3.c"
ADR r0,|L0.68|
#line 16 "test3.c"
cubed PROC
#line 17 "test3.c"
MUL r1,r0,r0
MULS r0,r1,r0
BX lr
#line 20 "test3.c"
main PROC
#line 24 "test3.c"
PUSH {r4,lr}
MOVS r3,#3
MOV r0,r3
BL cubed
MOV r2,r0
MOV r1,r3
ADR r0,|L0.76|
BL __2printf
ADR r0,|L0.92|
BL foo1
BL foo2
MOVS r0,#0
POP {r4,pc}
#line 29 "test3.c"
DCW 0x0000
|L0.60|
DCB "In foo2",0
|L0.68|
DCB "In foo1",0
|L0.76|
DCB "%d cubed = %d\n",0
DCB 0
|L0.92|
DCB "Hello world",0
AREA ||.arm_vfe_header||, DATA, READONLY, NOALLOC, ALIGN=2
DCD 0x00000000
__ARM_use_no_argv EQU 0
EXPORT __ARM_use_no_argv
EXPORT foo2 [CODE]
EXPORT foo1 [CODE]
EXPORT cubed [CODE]
EXPORT main [CODE]
IMPORT ||Lib$$Request$$armlib|| [CODE,WEAK]
IMPORT __2printf [CODE]
IMPORT _printf_percent [CODE]
IMPORT _printf_d [CODE]
IMPORT _printf_int_dec [CODE]
ATTR FILESCOPE
ATTR SETVALUE Tag_ABI_PCS_wchar_t,2
ATTR SETVALUE Tag_ABI_enum_size,1
ATTR SETVALUE Tag_ABI_optimization_goals,1
ATTR SETSTRING Tag_conformance,"2.06"
ATTR SETVALUE AV,18,1
ASSERT {ENDIAN} = "little"
ASSERT {INTER} = {TRUE}
ASSERT {ROPI} = {FALSE}
ASSERT {RWPI} = {FALSE}
ASSERT {IEEE_FULL} = {FALSE}
ASSERT {IEEE_PART} = {FALSE}
ASSERT {IEEE_JAVA} = {FALSE}
END
Orginal test3.S generated with armcc -S
Alignment seen on T32:
Alignment seen on T32, Tried to highlight the source code
______addr/line|code_____|label____|mnemonic________________|comment______________________________________________________|
| REQUIRE _printf_d
|foo2 PROC
| ; PATCH TOOL - START
16| PUSH {R0}
ST:00008098|B401 foo2: push {r0}
17| POP {R0}
ST:0000809A|BC01 pop {r0}
|#include<stdio.h>
|void foo2() ------------------ this is what I inserted
5|{
____ST:0000809C|A011________________add_____r0,pc,#0x44
6| printf("In foo2");
ST:0000809E|F000 bl_h 0x809E
ST:000080A0|B837 undef 0xB837
|void foo1() ------------------ this is what came by default
12|{
ST:000080A2|B401 foo1: push {r0}
13| printf("In foo1");
ST:000080A4|BC01 pop {r0}
|void foo1()------------------ this is what I inserted
ST:000080A6|A011 add r0,pc,#0x44
ST:000080A8|F000 bl_h 0x80A8
ST:000080AA|B832 undef 0xB832
I think you should put extra "#line" before the new instruction such as PUSH or POP.
The "#line" will reset the line number to the parameter of it.
Tried adding extra #line before inserted instructions but doesn't help.
It appears that generated assembly-object file doesn't have all the debug information as compared to object created from source. Any idea how they can be generated?
Here are the few things tried already
Compiler options: --debug --dwarf3 --debug_macros
Assembler options: --debug
Liner options: --bestdebug
--interleave doesn’t allow to reassemble the files.
can I ask your expectation?
As you say, the elf file includes many debug information.
What do you especially want?
