DescriptionEach OS function call returns osErrorISR. What is more, IS_IRQ() function returns value: 32 decimal. It should not happen, because none of the IRQ is defined.
osStatus_t osKernelInitialize (void) { osStatus_t stat; if (IS_IRQ()) { stat = osErrorISR; } else { if (KernelState == osKernelInactive) { #if defined(USE_FREERTOS_HEAP_5) && (HEAP_5_REGION_SETUP == 1) vPortDefineHeapRegions (configHEAP_5_REGIONS); #endif KernelState = osKernelReady; stat = osOK; } else { stat = osError; } } return (stat); }
/** \brief Get IPSR Register \details Returns the content of the IPSR Register. \return IPSR Register value */ __STATIC_FORCEINLINE uint32_t __get_IPSR(void) { uint32_t result; __ASM volatile ("MRS %0, ipsr" : "=r" (result) ); return(result); }
The most interesting fact is that, such problem occurs only if functions responsible of reading GPIO pin are used, such as:
LL_GPIO_IsInputPinSet(GPIOA, LL_GPIO_PIN_3) LL_GPIO_IsOutputPinSet(GPIOA, LL_GPIO_PIN_2)
There is a link to repository with my project: https://github.com/BusKetZz/STM32I would appreciate any help.Best regards
