instruction equivalent to movw,movt with position independent and PC relocatable.
Using movw and movt to load a label address into a register in Arm 32 architecture. but this is not position independent  code.
movw r1, #:lower16:ASM_NAME(forkx)
movt r1, #:upper16:ASM_NAME(forkx)
As per the manual also it specifies that it will be resolved at the link time.
Need a position independent code, so as per the manual adr, adrl can be used, but getting below error:
../asm-arm/unix_arm.S:115:1: error: unsupported relocation on symbol
adr r1, __be_forkx
../asm-arm/unix_arm.S:60:1: error: invalid instruction, did you mean: adr?
adrl r1, __be_forkx
it seems label can not be used in the aarch32, it is fine in aarch64 and works as intendent.
is the usage of adr command is improper? Is there a way to achieve this in aarch32?  is there any equivalent command that can be used?
  • The 1.s pasted earlier tries to read from the address of forkx. That read is not needed. I have updated the post with a modified 1.s.
  • I am trying this, with this individual file compilation is fine. now have to check in a arm32 platform
    in parallel started looking into the GCC compiler.
    with gcc adrl command is also supported but for the same adr or adrl command getting the below error:
    adrl r1, __be_forkx
    error:
    ../asm-arm/unix_arm.S: Assembler messages:
    ../asm-arm/unix_arm.S:61: Error: undefined symbol __be_forkx used as an immediate value
    GLOBL_REF(__be_forkx)
    #.global __be_forkx
    is added on top for global reference. is there anything going wrong?
    In addition, does the binary also use a global offset table (GOT)? If so, it might be easier to just keep track of the location of got and patch its entries. If a GOT is present and is being used, it is likely that the address of the global/external symbol forkx is in one of its entries. There might be a different assembler syntax to refer to a got entry for a global.
    adr/l won't work with external symbols.
  • 1.s v3 is working fine. Thanks a lot for all the help,
    even tried a 1.c file with extern variable, with -fPIC compiler option it generate a similar istruction.
    need one help to understand this assembly code.
    dist_forkx:
    .word forkx-load_addr
    hoe above 2 line able to map to external forkx at run time?
  • dist_forkx:
    They don't need to, because the need for directly knowing/mapping/fixing/reading the absolute address of forkx at runtime was removed. That's the basic concept of PIC - take advantage of the fact that relative distances between certain sections/symbols do not change once the binary is built.
    The general concept isn't also new. You can understand it, for e.g., if you look at the code generated when you call a function within the same binary. When bl calls into a function within the same binary, the assembler/linker performs such distance calculations, and emits appropriate PC-relative branches, insofar as allowed by the ISA and the ABI.
  • Got it.. Thanks a lot surati.
