I am trying to cross compile the lmbench for Android 9 and noticed below error.
Can some one help me on the same?
koti#~/lmbench/lmbench3$ make CC=/opt/android/standalone_toolchains/arm64/bin/aarch64-linux-android-gcc OS=linuxcd src && makemake[1]: Entering directory '/home/admin1/lmbench/lmbench3/src'+ make OS=linux CC=/opt/android/standalone_toolchains/arm64/bin/aarch64-linux-android-gcc CFLAGS= -O -static -DSYS5 -Dvalloc=malloc -DRUSAGE -DHAVE_uint=1 -DHAVE_uint64_t=1 -DHAVE_int64_t=1 -DHAVE_DRAND48 -DHAVE_SCHED_SETAFFINITY=1 -I/usr/include/tirpc LDLIBS=-lm -ltirpc O=../bin/linux allmake[2]: Entering directory '/home/admin1/lmbench/lmbench3/src'/opt/android/standalone_toolchains/arm64/bin/aarch64-linux-android-gcc -O -static -DSYS5 -Dvalloc=malloc -DRUSAGE -DHAVE_uint=1 -DHAVE_uint64_t=1 -DHAVE_int64_t=1 -DHAVE_DRAND48 -DHAVE_SCHED_SETAFFINITY=1 -I/usr/include/tirpc -pie -c lib_tcp.c -o ../bin/linux/lib_tcp.oclang80: warning: argument unused during compilation: '-pie' [-Wunused-command-line-argument]In file included from lib_tcp.c:9:./bench.h:38:10: fatal error: 'rpc/rpc.h' file not found#include <rpc/rpc.h> ^~~~~~~~~~~1 error generated.Makefile:246: recipe for target '../bin/linux/lib_tcp.o' failedmake[2]: *** [../bin/linux/lib_tcp.o] Error 1make[2]: Leaving directory '/home/admin1/lmbench/lmbench3/src'Makefile:114: recipe for target 'lmbench' failedmake[1]: *** [lmbench] Error 2make[1]: Leaving directory '/home/admin1/lmbench/lmbench3/src'Makefile:20: recipe for target 'build' failedmake: *** [build] Error 2
