Hi Guys
I'm looking for a guide or some general information or resources and tips for porting code targeted at a Microblaze processor to a ARM Cortex M3.
Danny
Just google search "cortex-m3 sample code", many examples for that.
Hope it can help you .
- https://www.arm.com/files/pdf/CortexM3_Uni_Intro.pdf
Danny_GOWIN said:Microblaze processor
You mean this: https://www.xilinx.com/products/design-tools/microblaze.html ?
The process is going to be much the same as porting code from any given architecture to any other architecture.
You will require:
It makes life much easier if you have full working development environments for both the original application on its original target and your intended "target".
Depending on the application, it might be as easy to just start from scratch ...
