How can I R/W general registers via CSAT tool?
Hi experts,
     I want to read/write Cortex-A53 core0 general registers (such as x0, x1, ...) via CSAT tool of DS5.
     I use the following command lines via csat tool, but I don't know what's the command line can read/write general registers.
     D:\Program Files\DS-5 v5.26.2\bin>csat.exe
     # CSAT - CoreSight Access Tool v2.6.3 #
    # [with Trace Commands v 2.0.1.1] #
    # Copyright 2007-2013 ARM Limited #
    CoreSight Component Data file read successfully.
    %>con USB
    Attempting to connect to ...USB
    Connected to:DSTREAM
    Base H/W: V2 Rev C-00
    TurboTAP Rev: 0.15
    DSTREAM Probe V1 Rev B-00
    Firmware: 4.31.0, Build 29
    %>chain dev=auto
    %>dvo 0
    Open connection to device ID : 0x4BA00477, version 0x00000006
    Msg returned with RVMOpenConn: ARM-DP Template using Rv-Msg.
    Is it possible to read/write general registers via csat tool? what's the command?
    Thanks for your attention!
Best Regards,
Emmy
