why DS5 ce version got segment falut on ubuntu1604?
I installed ds5 ce verson (version 5.27.0 build 5270014 dated 2017/04/27 10:47:07 GMT) on my ubuntu 1604.
why I got an segment falut when I run the ds5?
  • As of the 20th June 2017, there have been some Linux updates rolled out to the various distributions that might prevent Eclipse / DS-5 from starting.
    Symptom is that when DS-5 is started from the command line, it fails to start and reports :
    Segmentation Fault (core dumped)
    Answer
    Until the issue is resolved, there is a workaround described here.
    Workaround
    Work-around to this issue is as follows :
    The 'eclipse.ini' file (in <DS-5 Install Dir>/sw/eclipse ) needs to be modified.
    If you have write access to this directory then you can modify the file directly, otherwise take a copy.
    Modify 'eclipse.ini' such that lines :
    -vm
    ../java/lib/amd64/server/libjvm.so
    are changed to read :
    -vm
    ../java/bin
    and then save the updated eclipse.ini
    If you have modified the supplied eclipse.ini file then DS-5 can be launched as normal.
    If you have taken a copy of the 'eclipse.ini' then then this needs to passed to DS-5 on start-up
    This can be done using the '–-launcher.ini' command line option. See the 'Example' section.
    Example
    An example command line is shown below that shows a modified 'eclipse.ini' file being passed into DS-5 :
    /usr/local/DS-5_v5.27.1/bin/eclipse --launcher.ini ~/eclipse.ini
     where :
    /usr/local/DS-5_v5.27.1 is the install directory of DS-5 v5.27.1
    The modified 'eclipse.ini' file is located in the users home directory.
    Related Information
    This issue also affects standard Eclipse, see the bug report here
