Hi, i'm working in Keil with the NXP Kinetis MK20X256VLH7 (Teensy 3.2 microcontroller).
The microprocessor seems to get stuck when i wrote to these registers:
PORTB->PCR[16] = (uint32_t)(PORT_PCR_MUX(0x03));
PORTB->PCR[17] = (uint32_t)(PORT_PCR_MUX(0x03));
PORTD->PCR[4] = (uint32_t)(PORT_PCR_MUX(0x04));
PORTD->PCR[7] = (uint32_t)(PORT_PCR_MUX(0x04));
The problem seems to be that the pin configuration has to be done on the RTE_Device.h file, however i don't know how to reference them in my project.
By the way, I'm configuring the peripherals from the scratch.
I found my mistake
It requires enable both UART0 and PORTB clocks, i was enabling only UART0 clock.
