win10 22H2 arm ds-5 make go error
Project compilation error:armclang : clang frontend command failed,but the Project is ok on other PC,
What's different is that,the version of windows OS
win10 22H2 is go error .
how can I repair this question,THX!
  • Hi
    My name is Stephen and I work at Arm.
    Sorry that you've hit a problem.
    To help us investigate:
    1) Which version of Arm DS or DS-5 are you using, exactly (look in Help > About)
    2) What is the armclang command-line that is failing?
    3) Are you building your project via the IDE GUI, or a from a makefile/script?
    4) What is the OS version on the other (working) PC?
    Some screen-shots of your failing setup might also help.
    Thank you.
    Stephen
