Hi Experts,
Does the open source clang compiler supports the ARM architecture ?
I had seen that the ARM Compiler 6 is on LLVM based and it is only trial version I think.
In future any plans to release so, like instead of gcc the clang could be given as open source ?
clang compiler already supports ARM architecture. You can download and build clang from Clang - Getting Started if you want. Depending on the application you are developing, you might need libraries and a linker.
The advantage of using ARM Compiler 6 is that it just works and it's professionally supported: you would be productive from day 1.
Ciao,Stefano
Hi Stefano,
Thanks for the reply.
Can you bit elaborate on the master piece of work done on ARM Compiler 6 ?
Is it so tedious to build the clang on own along with the libraries and linker.
I initially thought it will be like GNU tool chain readily available.
Regards,
techguyz
I recommend looking at "The ELCC Embedded Complier Collection" found at http://ellcc.org/
ELLCC (pronounced “elk”) is a project to using clang and the LLVM compiler infrastructure. The primary emphasis of the ELLCC project is to create an easy to use multi-target cross compilation environment for embedded systems. There is ARM support.
ARM Compiler 6 uses clang as a basis for the compiler but it integrates additional patches and optimizations specific to ARM.
It also includes armlink and the libraries for bare-metal development.
Hope this helps.
Cheers,Stefano
Thanks for the insight Stefano.
Cheers,
Techguyz
