I've been trying to get Keil uVision5 to compile code for the FRDM-K64F so it uses the FPU with instructions such as VADD and VMUL.
The code I'm using is the one for the Blinky standalone sample code found in Keil's software pack: MDK5 - FreescaleFRDM-K64F
I've tried changing the "Floating point hardware" option in Keil from "Not Used" to "Use Single Precision", but all I get it to do is use VMOV but still calling __aeabi_dadd and __aeabi_dmul
Any help is welcome!
I answered myself! Hoping to help anyone, here it goes:
The Cortex-M4 FPU does single precision arithmetic, not double. So if your code uses doubles, all of the related expressions get extended to double. Since the FPU can't take care of doubles, all of the double operations are done by software routines by means of the integer ALU :/
In my code I had the following function:
float CircleArea(float r){
return 3.14159 * r * r;
VMOV r0,s16
BL.W __aeabi_f2d ; float-to-double routine
VMOV dl0,r0,rl
VMOV d12,r0,r1
VLDR d0,[pc,#0x110]
VMOV r2,r3,d0
BL.W __aeabi_dmul ; double-multiply routine
VMOV d11,r0,r1
VMOV r2,r3,d10
VMOV d9,r0,r1
BL.W __aeabi_d2f ; double-to-float routine
VMOV s0,r0
...which has a double constant! So it calls routines to convert the existing floats to double, and then operate on doubles, which is done by integer software.... NOT what I wanted.
A subtle change made wonders:
return 3.14159f * r * r;
VLDR s0,[pc,#0xF4]
VMUL.F32 s0,s1,s0
VMUL.F32 s0,s0,s1
... which does exactly what's expected from an FPU.
So there you have it! Avoid using doubles. Maybe there's a compiler option or preprocessor directive for this. Anyone?
