Hi, I have a license for FVP (it also includes FVP_Base_Cortex-A55 8cores) and I want to connect the A55 8 core model in Arm DS.
So, I try to find the model connetion : New > Model Connection > Target Selection > Arm FVP >
But, I can see only FVP_Base Cortex A55x1, x2, x4. Where can I find the 8 cores model?
Thank you!
My name is Stephen and I work at Arm.
You've replied:
>I found how to add FVP_Base_Cortex-A55x8 model by adding a new modelYes, that's right. As you have discovered, you can create a new model configuration with:developer.arm.com/.../Create-a-new-model-configuration
Hope you are now able to run & debug successfully on Cortex A55x8 !
Stephen
Thank you for reply Stephen! :)
No problem :) Please mark this as "Answered" if you are happy.
