How to estimate RAM requirements?
I have a basic prototype program running in Arm Development Studio. This needs to execute in a system with very limited resources.  How should I estimate the total RAM needed to run it?
It is a C++ program. How can I specify the maximum heap and stack sizes?
Best regards
David
  • Hi David
    To estimate stack usage, see
    https://developer.arm.com/documentation/100748/0616/Writing-Optimized-Code/Stack-use-in-C-and-C--
    Heap usage can be difficult to estimate, because it depends on run-time use of malloc/free (or new/delete for C++), though a program can at least test the return result of e.g. malloc() to see whether the heap is exhausted.
    Placing the stack and heap is best done with a scatter file, see
    https://developer.arm.com/documentation/100748/0616/Mapping-Code-and-Data-to-the-Target/Placing-the-stack-and-heap-with-a-scatter-file
    Take a look at the scatter file "scatter.scat" in the "startup_Armv8-Ax1_AC6" example (for Cortex-A53) or in the startup_Cortex-M7_AC6 example (for Cortex-M7).
    You will also need to allocate space for the variables in the program, for both RW/.data and ZI/.bss.  The linker's output from its "--info=totals" switch can help here, for example:
    Image component sizes
          Code (inc. data)   RO Data    RW Data    ZI Data      Debug
          1548        352        148          0      11688       7611   Object Totals
             0          0         32          0       8192          0   (incl. Generated)
            62         16          3          0          0          0   (incl. Padding)
          9372        458        480         20        576       7340   Library Totals
            28          4          3          0          0          0   (incl. Padding)
         10920        810        628         20      12264      10931   Grand Totals
         10920        810        628         20      12264      10931   ELF Image Totals
         10920        810        628         20          0          0   ROM Totals
        Total RO  Size (Code + RO Data)                11548 (  11.28kB)
        Total RW  Size (RW Data + ZI Data)             12284 (  12.00kB)
        Total ROM Size (Code + RO Data + RW Data)      11568 (  11.30kB)
    Hope this helps
    Stephen
  • Hi Stephen
    Thanks for your answer,
    David
