I downloaded the latest DS-5 and got the evaluation license.
It seems like I can only capture debuggable apk on streamline 7.7.
Is this the case?
Have I done something wrong?
Hi
If you have downloaded Arm Mobile Studio, then yes this is correct as that package is targeted primarily and Android application developers.If you have downloaded Arm Development Studio, then no, you should be able to profile both Linux and Android targets (along with bare-metal targets). For Linux targets, along with Android targets where you are interested in profiling the whole system as root (for example on an engineering build of Android), you would follow the traditional path of pushing gatord to the device, then from the "Start" tab in Streamline select "TCP/Advanced" and enter the hostname or IP address of the device you wish to profile.Please refer to:* Android Target Setup Guide https://developer.arm.com/documentation/101813/0707 (in particular "System profiling on an Android device")* Bare Metal Setup Guide developer.arm.com/.../0707* Linux Target Setup Guide https://developer.arm.com/documentation/101814/0707depending on your use case, along with the User Guide https://developer.arm.com/documentation/101816/0707 for general information.
