Arm streamline NI DAQ 6211
Hi, I am trying to measure power using 'NI DAQ USB-6211' in arm streamline.
Arm Streamline User Guide Version 7.5
According to the page above, when energy probe is used, the maximum shunt voltage is 165mV and the appropriate resistor must be selected according to the formula written on the page.
Then what is the maximum shunt voltage when using USB-6211 above, and what formula should I use to select the appropriate resistor?
(USB-6211 Specifications - National Instruments (ni.com) USB-6211 spec)
