I came across optimized ARM version of memcpy while going through disassembly and I was wondering if there is one for memcmp, didn't find one in disassembly. Please let me know if there is one. I am using Cortex-R7.
Thanks.
Hello, as far as a I know there is only a single standard implementation of memcmp (per core) in the standard library.If you link with microlib (--library_type=microlib) there is a smaller (but likely slower) implementation.
Thank you! Should the memory address be aligned for memcmp as well?
It does not need to be, as Arm processors can handle unaligned accesses (on normal memory). If you declare structures as __unaligned, you will likely get slower performance.
