Execute code in ram using LPC2XX and number of breakpoints
I need to execute code under test in RAM, to be able to set more than 2 hardware breakpoints. All the others objects will be located in flash, with startup code, using a scatter file to locate any object in correct area. But what about debug and breakpoints in this RAM aera ?
I use Keil Arm tools and debug scripts. I'm a little novice about ARM such capabilities. Does anyone have an idea if only it's possibe, especially to set breakpoints in a ram aera used to execute code ?
kind regards
jean-marc
