1. aarch64-elf-gcc need use glibc2.14 while our central version up to glibc-2.12 only2. I have downloaded glibc-2.14 in my local directory3. There is a limitation in my environment that if I add glibc-2.14 path into LD_LIBRARY_PATH directly, DS-5 eclipse could not open successfully
Therefore, I want to set glibc-2.14 path after I open DS-5 eclipse4.I try to assign -I or -L with local directory with ARM DS-5 eclipse to include path>>>>>>>>>>>>>>>>>>>>>>>>> Command >>>>>>>>>>>>>>>>>>>>>>>>>>aarch64-elf-gcc -I<local_path>/glibc-build/include -L<local_path>/glibc-build/lib -o "gcc5.axf" ./src/gcc5.o
>>>>>>>>>>>>>>>>>>>>>>>> Result >>>>>>>>>>>>>>>>>>>>>>>>>>>aarch64-elf-gcc: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by aarch64-elf-gcc)
Hi YL Shen
Which type/version of Linux machine are you using? e.g. Ubuntu 16.04 LTS or Red Hat Enterprise 6 ?
Are you trying to compile with gcc on the command-line or from within a DS-5 Eclipse project?
If you are trying to compile with gcc on the command-line, then you can open a new shell and set the LD_LIBRARY_PATH environment variable just for that shell.Alternatively, you can set LD_LIBRARY_PATH for each individual invocation of gcc with e.g.:LD_LIBRARY_PATH=/path/to/glibc-2.14:$LD_LIBRARY_PATH aarch64-elf-gcc -o "gcc5.axf" ./src/gcc5.oThis command is all on one line, and no export is needed, and can easily be added into a makefile.
If you are trying to compile with gcc from within a DS-5 Eclipse project, then try appending the new LD_LIBRARY_PATH=/path/to/glibc-2.14 into the Project > Properties > C/C++ Build > Environment.
There are other references to the error "/lib64/libc.so.6: version `GLIBC_2.14' not found" on the web, e.g. see unix.stackexchange.com/.../176489
Hope this helps
Stephen
