I would like to download the GCC compiler for ARMv7-A. I would like it to support thumb and NEON instructions. Where can I get the latest version?
Also, are there any other open source compilers that meet the above requirements?
Hi @haris,
You can find a good selection of GNU compilers and the rest of the toolchain as provided by Linaro - Software Downloads at Linaro.
Distributions such as Ubuntu, Fedora and OpenSuSE tend to already include cross-compiler toolchains which are derived from the Linaro releases. The details of which package and how to install it are up to the distribution.
There is another popular compiler toolchain, "clang" ("clang" C Language Family Frontend for LLVM) which is based on the LLVM project. The best way to get hold of this is from your favorite Linux distribution package manager, as above, if you are on Ubuntu or Debian then there is a snapshot of the latest code located here: LLVM Debian/Ubuntu nightly packages
Thanks,
Matt
The downloads on the Linaro page under "tool chains" should all support Cortex-A devices. For the Cortex-R/M it's the links under "Bare-metal". And yes, GCC supports Thumb and NEON (assuming appropriate target selected).
Thank you for the answer.
However, I see that the GCC version at the Linaro site supports Cortex-M and Cortex-R processors.
Any version for Cortex-A processors? That supports thumb and NEON?
Thank you
