IAR Embedded Workbench external terminal
I am using IAR Embedded Workbench software for programming MSP430F5529 microcontroller. I would like to process my data in MSP430 but after that display/print these data to the external terminal or to the LabView, not to I/O terminal which is part of IAR. The board is connected to the PC by USB (FET Debugger) so there is UART port in device manager. Is there any possibility?
Thank you,
Daniel
