Hello
I want to connect float license server.
but, there is below error ?
Do you know that is this Server side issue or client side issue ?
thanks,
YoonSang
<<logs>>
System Information: OS name: Linux Java version: Java HotSpot(TM) 64-Bit Server VM, 25.45-b02 PATH environment variable: /home/yoonsang.park/DS-5_v5.29.1/bin:/home/yoonsang.park/DS-5_v5.29.1/sw/java/bin:/home/yoonsang.park/ndk/android-ndk-r8:/usr/local/sbin:/usr/local/bin:/usr/sbin:/sbin:/bin:/usr/games:/opt:/usr/lib/jvm/java-6-sun-1.6.0.16/bin:/usr/bin:usr/bin:/home/yoonsang.park/bin:/home/yoonsang.park/bin/apache-ant-1.8.4/bin:/opt/p4v-2014.1.888424/bin:/home/yoonsang.park/intel-3.10
Product Information: Version: 5.29.1 Build number: 5291003 Build date: 201807 Selected toolkit: DS-5 Compiler-only ARM_TOOL_VARIANT environment variable: arm.tool.variant system property:
Host IDs: 24F5AAEA77AA: enp4s0 (Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller)
Licenses are searched for in the following locations: ARMLMD_LICENSE_FILE environment variable: "8224@168.219.209.142" ARMLMD_LICENSE_FILE in file "/home/yoonsang.park/.flexlmrc": "8224@168.219.209.142" LM_LICENSE_FILE environment variable: "8224@168.219.209.142" LM_LICENSE_FILE in file "/home/yoonsang.park/.flexlmrc": "8224@168.219.209.142"
License Mapping Information: ARM_PRODUCT_DEF environment variable: not set ARM_PRODUCT_PATH environment variable: "/home/yoonsang.park/DS-5_v5.29.1/sw/mappings" ARM_TOOL_VARIANT environment variable: "" ARM_CONFIG_PATH environment variable: "/home/yoonsang.park/.arm/DS-5_v5.29.1"
Licenses used recently (Streamline and DS-5 Debugger only): (none)
License checkout log (Streamline and DS-5 Debugger only): 02/08/2018 17:09:17: Failed to checkout [Streamline.TraceMerging/5.0201806], error message: No such feature exists. 02/08/2018 17:09:17: Failed to checkout [Streamline.Fastline.Wizard/5.0201806], error message: No such feature exists. 02/08/2018 17:09:17: Failed to checkout [Streamline.BareMetal.Barman/5.0201806], error message: No such feature exists. 02/08/2018 17:09:17: Failed to checkout [Streamline.32Bit.BasicCounters/5.0201806], error message: No such feature exists. 02/08/2018 17:09:17: Failed to checkout [Streamline.32Bit.AllCounters/5.0201806], error message: No such feature exists. 02/08/2018 17:09:17: Failed to checkout [Streamline.64Bit.BasicCounters/5.0201806], error message: License map could not route the specified feature: "Streamline.64Bit.BasicCounters" 02/08/2018 17:09:17: Failed to checkout [Streamline.64Bit.AllCounters/5.0201806], error message: License map could not route the specified feature: "Streamline.64Bit.AllCounters" 02/08/2018 17:08:26: Failed to checkout [Streamline.TraceMerging/5.0201806], error message: No such feature exists. 02/08/2018 17:08:26: Failed to checkout [Streamline.Fastline.Wizard/5.0201806], error message: No such feature exists. 02/08/2018 17:08:26: Failed to checkout [Streamline.BareMetal.Barman/5.0201806], error message: No such feature exists. 02/08/2018 17:08:26: Failed to checkout [Streamline.32Bit.BasicCounters/5.0201806], error message: No such feature exists. 02/08/2018 17:08:26: Failed to checkout [Streamline.32Bit.AllCounters/5.0201806], error message: No such feature exists. 02/08/2018 17:08:26: Failed to checkout [Streamline.64Bit.BasicCounters/5.0201806], error message: License map could not route the specified feature: "Streamline.64Bit.BasicCounters" 02/08/2018 17:08:26: Failed to checkout [Streamline.64Bit.AllCounters/5.0201806], error message: License map could not route the specified feature: "Streamline.64Bit.AllCounters" 02/08/2018 17:08:12: Failed to checkout [Streamline.TraceMerging/5.0201806], error message: No such feature exists. 02/08/2018 17:08:12: Failed to checkout [Streamline.Fastline.Wizard/5.0201806], error message: No such feature exists. 02/08/2018 17:08:12: Failed to checkout [Streamline.BareMetal.Barman/5.0201806], error message: No such feature exists. 02/08/2018 17:08:12: Failed to checkout [Streamline.32Bit.BasicCounters/5.0201806], error message: No such feature exists. 02/08/2018 17:08:12: Failed to checkout [Streamline.32Bit.AllCounters/5.0201806], error message: No such feature exists. 02/08/2018 17:08:12: Failed to checkout [Streamline.64Bit.BasicCounters/5.0201806], error message: License map could not route the specified feature: "Streamline.64Bit.BasicCounters" 02/08/2018 17:08:12: Failed to checkout [Streamline.64Bit.AllCounters/5.0201806], error message: License map could not route the specified feature: "Streamline.64Bit.AllCounters" 02/08/2018 15:18:21: Failed to checkout [Streamline.TraceMerging/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 15:18:21: Failed to checkout [Streamline.Fastline.Wizard/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 15:18:21: Failed to checkout [Streamline.BareMetal.Barman/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 15:18:21: Failed to checkout [Streamline.32Bit.BasicCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 15:18:21: Failed to checkout [Streamline.32Bit.AllCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 15:18:21: Failed to checkout [Streamline.64Bit.BasicCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 15:18:21: Failed to checkout [Streamline.64Bit.AllCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:50:02: Failed to checkout [Streamline.TraceMerging/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:50:02: Failed to checkout [Streamline.Fastline.Wizard/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:50:02: Failed to checkout [Streamline.BareMetal.Barman/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:50:02: Failed to checkout [Streamline.32Bit.BasicCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:50:02: Failed to checkout [Streamline.32Bit.AllCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:50:02: Failed to checkout [Streamline.64Bit.BasicCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:50:02: Failed to checkout [Streamline.64Bit.AllCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.TraceMerging/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.Fastline.Wizard/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.BareMetal.Barman/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.32Bit.BasicCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.32Bit.AllCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.64Bit.BasicCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.64Bit.AllCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.TraceMerging/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.Fastline.Wizard/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.BareMetal.Barman/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.32Bit.BasicCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.32Bit.AllCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.64Bit.BasicCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.64Bit.AllCounters/5.0201806], error message: User/host not on INCLUDE list for feature. 02/08/2018 14:46:28: Failed to checkout [Streamline.TraceMerging/5.0201806], error message: User/host not on INCLUDE list for feature.
From the above I see the following:" Selected toolkit: DS-5 Compiler-only"Open the DS-5 debugger -> Help -> Arm license manager, and select DS-5 Ultimate Edition (or Professional Edition) from the toolkit pulldown. This should set all the appropriate settings for your license.If you only have a compiler license, then you cannot use Streamline. Please contact your Arm sales contact for more information.
