DStream on windows 10 :issue CLI33
Hi
 I used to launch regression scriipts from python scripts and DStream commands
On windows 7 , no problem but on windows 10, it sounds something is missing in the default installation or configuration
Basically  I have a command launched from a cmd windows which is
self.cmd_str += "debugger --cdb-root " + self.CONFIGDB_EXTENSION + " --cdb-entry " + self.DS5_CONFIG_SCU + \
" --cdb-entry-param " + self.DS5_ADDR + " --continue_on_error=true --image " + \
os.path.join(self.REG_TC_DIR, module, tc_name, self.device_name + "_" + tc_name + "_scu.elf") + \
" --script=" + script_ds + " --log_file=regtest.log"
with some variable assigned dynamically. Iload a elf file along with a Debugger script DS file , with a specific path for the DB
So when launching this
os.sys(self.cmd_str)
the first message I have is :
ERROR(CLI33) Failed to Find the default logging file for level: {0}
So all the log done by my ds script which is:
# show debugger version
show version
memory 0x00000000 0x7FFFFFFF noverify
I also have issue when  I try to dump memory to the drive
# dump a dummy file to inform elf has been loaded
dump memory elf_loaded.tmp 0x20000000 0x20000004
In that case Ihave the following error message:
ERROR(COR108) " Dumping memory to "elf_loaded.tmp" [100%]
# in ....while executing :dump memory elf_loaded.tmp 0x20000000 0x20000004
! unable to write image "C:\Progam File\DS-5-v5.27.0\bin\elf_loaded.tmp
I have a DStream ST, and DS5 version is 5.27.0
Any clue on error code would help understand the real cause.
Do we have to do some extra steps on windows 10 to configure DStream/DS5 ?
thanks in advance
claude
  • Hi Claudio,
    The last error message "unable to write image "C:\Progam File\DS-5-v5.27.0\bin" leads me to believe that this may be a permissions issue.
    You could try save the log file and memory dump to another location that you know is writable, or alternatively run the command prompt as administrator to see if this is indeed the issue.
    Hope this helps,
    Lukas
  • Hi Lukas,
    yes this was what I have tried after discussing with some IT guys who told me there are some restrictions of file access on some folder.
    Since I was launching the command being in the DS5 standard installation directory (C:\Progam File\DS-5-v5.27.0\bin) .
    I tried to launch from another folder so it is fine since the files are written in another directory.
    I try to run as admin but it is not obvious since the comand is launched from a python script at the end.
    thanks and regards
    claude
