RIT Interrupt in Keil uVision
I want to use RIT interrupt to generate a interrupt after a specific time period. I am using keil uVision 4 on lpc1768 device.
I have the code that is compiled without any errors. But when ever i try to debug the code, i donot see the RITCOUNTER value to increase and RIT interrupt never generated because of which the ISR routine is never reached. Can anyone help me to figure out what i am doing wrong.
Thank you
Asha
  • Hello,
    According to the user manual www.nxp.com/.../UM10360.pdf
    i have made sure that i have a value for the RICOMPVAL register, set the bit in the RICTRL register. I have also enabled the NVIC register for the RIT interrupt. When i am using the debug session, these registers to get the necessary value. Only the RICOUNTER doesnt increase with clock cycles as mentioned in the manual. This is where i am not sure what i am doing wrong. Please help.
