Bare metal project, trying to get the right sequence of operations for initializing the MMU and L1, L2 caches. This is my current code:
uint32_t _mmu_init(void){ uint32_t *L1_TBL_ptr; KERNEL_DATA_STRUCT_PTR kernel_data; uint32_t sctlr; uint32_t dacr; uint32_t actlr; #if PSP_HAS_DATA_CACHE && PSP_HAS_MMU _int_disable(); _L2_pl310_cache_disable(); _dcache_invalidate(); _icache_invalidate();
// Enable dcache prefetch actlr = __MRC(15, 0, 1, 0, 1); actlr |= BM_ACTLR_PP; __MCR(15, 0, actlr, 1, 0, 1); // Enable Branch Prediction sctlr = __MRC(15, 0, 1, 0, 0); //get sctlr sctlr |= BM_SCTLR_Z; //set branch prediction enable __MCR(15, 0, sctlr, 1, 0, 0); //write it back __DSB(); __ISB(); // Allocate L1 cache MMU table L1_TBL_ptr = _mem_alloc_align(MMU_L1_TBL_SIZE, MMU_L1_TBL_ALIGN); // Clear the table - sets all sections to FAULT (see section 9.4) _mem_zero(L1_TBL_ptr, MMU_L1_TBL_SIZE); // Write the L1 table address to the TTBR0 __MCR(15, 0, (uint32_t)L1_TBL_ptr, 2, 0, 0); // Save table address in kernel data kernel_data->L1_TBL_PTR = L1_TBL_ptr; // Create the basic translation table entries that are known - ROM boot area, // peripherals, ROM, RAM, etc. These will be part/design specific _mmu_iMX6DQ(kernel_data->CORE_ID);
// Set Client mode for all Domains - see section 9.6.4 dacr = 0x55555555; __MCR(15, 0, dacr, 3, 0, 0); // Write DACR // Enable SMP actlr = __MRC(15, 0, 1, 0, 1); actlr |= BM_ACTLR_SMP; __MCR(15, 0, actlr, 1, 0, 1); // Enable the SCU - see section 2.2.1 in the ARM A9 MPCore TRM// SCU_CNTRL |= SCU_CTRL_ENB; _int_enable();#endif __DSB(); __ISB();
_dcache_enable(); _icache_enable(); //Invalidate the TLB - see sec B4.2.2 in the ARMv7 Architecture RM __MCR(15, 0, 0, 8, 7, 0); // Enable the memory management unit sctlr = __MRC(15, 0, 1, 0, 0); //get sctlr sctlr = sctlr | BM_SCTLR_M; //set MMU enable bit __MCR(15, 0, sctlr, 1, 0, 0); //write modified sctlr _int_enable(); return 0;
Processor is an iMX6Q. Used memory is flat mapped. All of the MMU table entries are 0 (fault) except the following:
0-0x00900000 1MB section sizes, device, RW all, sharable - boot rom and some peripherals
00900000 - 00A00000 1MB section, strongly ordered, RW all, shareable - OCRAM
00A00000 - 10000000 1MB sections device, RW all shareable
10000000-10100000 - 1MB section, WB, RO all - 1MB code memory for core 0
10100000 - 1MB section, WB all, RW, nX - 1MB data memory for core 0
I've looked at the MMU table, and the used entries appear correct. The error comes when I enable interrupts (next to last line). A prefetch exception occurs (vector table is at 0x1000008C0).
Trying to determine what's going on. Any ideas?
