Hi
I am porting an example code from neno intrinsic to helium intrinsic, it used the Transpose related intrinsic like (vtrn_u32/ vtrn_u8), how can do the transpose operation in helium, as there is no related intrinsic in helium.
Thanks.
Helium MVE (Matrix Vector Extension) is a microarchitecture extension to the CM85 and CM55 kernels on the Armv8.1-M architecture. Similar to Neon technology in Cortex-A devices, Helium provides a set of SIMD-like instructions.
Would you please tell me which helium intrinsic can do the transpose? thanks.
Have you seen this documentation?
https://developer.arm.com/documentation/102107a/0100/Floating-point-4x4-matrix-transposition
https://developer.arm.com/documentation/102107a/0100/Integer-8-bit-4x4-matrix-transposition
