Why the the Dynamic defect pixel correction module not work, i just follow the Arm_Mali-IV009 tuning guide, is there any possible reason?
   Current dynamic DPC algorithm, has a few parameters like Sigma_in is the noise estimation, DP_slope is alpha blend between original and corrected images, DP_threshold is use to controls strength of dynamics DPC etc.
Some other paramters i just set it to default value, then i follow the tuning procedure in the Arm_Mali-IV009 tuning guide. It's didn't work. I'm sure the image have some hot pixel in the flat region  which i need to remove it. Is there any suggestions to help me to further tuning this module ?
