At https://developer.arm.com/documentation/ddi0413/c/debug-access-port/swj-dp/swd-and-jtag-select-mechanism there is the step:
The 16-bit JTAG-to-SWD select sequence is defined to be 0111 1001 1110 0111, MSB first. This can be represented as 16'h79E7 transmitted MSB first or 16'hE79E when transmitted LSB first.
This is not the same thing.
Or does this actually not matter?
In case it does matter, which one is correct? I see code online with either implementation.
