About the difference between the terms l3_cache and ll_cache
HI ALL:
I came across the terms LL_CACHE_MISS ,LL_CACHE, L3D_CACHE_REFILL, L3D_CACHE when I was learning about ARMV8 PMU events. I am confused about the difference in the definition of LL cache and L3 Cache, are they equivalent?
  • Usually, Yes. But need to check the CPUECTLR configuration in firmware.
    If CPUECTLR.EXTLLC is set: This event counts any cacheable read transaction which returns a data source of "interconnect cache"/ system level cache.
    If CPUECTLR.EXTLLC is not set: This event is a duplicate of the L*D_CACHE_RD event corresponding to the last level of cache implemented.
