I am using cortex M4 simulator in ARM DS.
I am having a function with name function1. Attached the code for reference
Can anybody suggest me any modification in that function such that runtime will be reduced ?
Regards
GBS
Unable to add code . Now attaching here.
/* ============================================================================ Name : runtime_opt.c Author : GB Version : Copyright : Your copyright notice Description : Hello World in C, Ansi-style ============================================================================ */
#include <stdio.h>#include <stdlib.h>#include "stdint.h"#include <arm_acle.h>
typedef unsigned char uint8;typedef unsigned short uint16;typedef unsigned int uint32;typedef signed char sint8;typedef signed short sint16;typedef signed int sint32;typedef unsigned char boolean;
# define D_LENGTH 400# define B_LENGTH 64# define P_PER_GR 16u
typedef struct{ uint16 u_IdxD; uint16 u_bField[3];}struct1;
typedef struct{ uint16 u_IdxB; boolean b_Is; uint16 u_SR; uint16 u_BI; uint16 u_BIRND; uint16 u_BIRNDP; uint16 u_BIRNDN; uint16 u_BIRPD; uint16 u_BIRPDP; uint16 u_BIRPDN; uint16 u_MfPS; uint16 u_MfPSRP; uint16 u_MfPSRN; uint16 u_IDMO; uint16 u_IDPO;
}struct2;
void function1(const struct1* ind, const uint16 a_SpRext[][B_LENGTH], const uint16* p_IdMaxMf, const uint32 u_NP, struct2* p_Pks);
int main(void) { uint16 index = 0;
// Function arguments struct1 arg1[2][P_PER_GR]; uint16 arg2[2][D_LENGTH * B_LENGTH]; uint16 arg3[2][D_LENGTH]; uint8 arg4[2]; struct2 arg5[P_PER_GR];
//Inputs for(index=0;index<P_PER_GR;index++) { arg1[0][index].u_IdxD = 0; arg1[0][index].u_bField[0] = 0; arg1[0][index].u_bField[1] = 0; arg1[0][index].u_bField[2] = 0;
for(index=0;index<D_LENGTH * B_LENGTH;index++) { arg2[0][index] = 16384; arg2[1][index] = 16384; }
for(index=0;index<D_LENGTH;index+=7) { arg3[0][index] = 1; arg3[0][index+1] = 5; arg3[0][index+2] = 10; arg3[0][index+3] = 15; arg3[0][index+4] = 20; arg3[0][index+5] = 25; arg3[0][index+6] = 31;
} arg4[0] = 0; arg4[0] = 1;
function1(&arg1[0][0], &arg2[1][0], &arg3[1][0], arg4[0], &arg5[0]);
return EXIT_SUCCESS;}
{ uint32 u_Cnt; uint32 u_NP_L = u_NP; uint16 u_IdxD; uint16 u_IDMO ; uint16 u_IDPO ; uint16 u_NofDoppler = (uint16)D_LENGTH; const uint16* p_SBNextIn, *p_SBPrevIn; struct2* p_DPCurr; struct1* p_HPCurr;
for (u_Cnt = 0u; u_Cnt < u_NP_L; u_Cnt++) {
p_HPCurr = (ind + u_Cnt); p_DPCurr = (p_Pks+u_Cnt);
u_IdxD = p_HPCurr->u_IdxD; u_IDMO = p_DPCurr->u_IDMO; u_IDPO = p_DPCurr->u_IDPO;
p_SBNextIn = a_SpRext[u_IdxD]; p_DPCurr->u_MfPSRN = *(p_SBNextIn+p_DPCurr->u_IdxB);
p_DPCurr->u_BIRND = *(p_IdMaxMf+u_IdxD); p_DPCurr->u_BIRNDN = *(p_IdMaxMf+u_IDPO); p_DPCurr->u_BIRNDP = *(p_IdMaxMf+u_IDMO);
Code: Insert->code.
Thanks,
Can anybody help me in this ?
Regards,
