Hi, We are able to use the armcc 5.06u6 as a standalone compiler as well by setting the required environment variables using: export ARM_PRODUCT_DEF=/opt/arm/developmentstudio-2019.0/sw/mappings/gold.elmapexport ARM_CONFIG_PATH=/home/uab/.arm/ds/2019.0export PATH=$PATH:/opt/arm/developmentstudio-2019.0/bin/../sw/ARMCompiler5.06u6/bin:/opt/arm/developmentstudio-2019.0/bin:/opt/arm/developmentstudio-2019.0/sw/java/binHowever, in building the trustzone directory of the Qualcomm chipcode for MSM8909, we're getting the following error: Error: C9580E: QSP is not available with the current toolkit and license. Check that ARM_TOOL_VARIANT is set correctly.Information about this error is available at: http://ds.arm.com/support/lic81 General licensing information is available at: http://ds.arm.com/support/licensing/ If you need further help, provide this complete error report to your supplier or license.support@arm.com. - ARMLMD_LICENSE_FILE: unset - LM_LICENSE_FILE: unset - ARM_TOOL_VARIANT: unset - ARM_PRODUCT_PATH: unset - Product location: /opt/arm/developmentstudio-2019.0/sw/mappings - Toolchain location: /opt/arm/developmentstudio-2019.0/sw/ARMCompiler5.06u6/bin - Selected tool variant: productProduct: Arm Development Studio Gold Edition 2019.0Component: ARM Compiler 5.06 update 6 (build 750)Tool: armcc [4d3637]Fatal error: C3903U: Argument 'QSP.no_neon.no_vfp' not permitted for option 'cpu'.Is this because of a feature (QSP) being missing in the professional gold edition of DS-5? We have also tried explicitly setting ARM_TOOL_VARIANT and found no change.
Thanks zheng,I had already set the license and the toolchain, what was left was setting env vars ARM_PRODUCT_DEF and ARM_CONFIG_PATH in linux to the new 2020 version. Trustzone component builds now.
