Hi, We are able to use the armcc 5.06u6 as a standalone compiler as well by setting the required environment variables using: export ARM_PRODUCT_DEF=/opt/arm/developmentstudio-2019.0/sw/mappings/gold.elmapexport ARM_CONFIG_PATH=/home/uab/.arm/ds/2019.0export PATH=$PATH:/opt/arm/developmentstudio-2019.0/bin/../sw/ARMCompiler5.06u6/bin:/opt/arm/developmentstudio-2019.0/bin:/opt/arm/developmentstudio-2019.0/sw/java/binHowever, in building the trustzone directory of the Qualcomm chipcode for MSM8909, we're getting the following error: Error: C9580E: QSP is not available with the current toolkit and license. Check that ARM_TOOL_VARIANT is set correctly.Information about this error is available at: http://ds.arm.com/support/lic81 General licensing information is available at: http://ds.arm.com/support/licensing/ If you need further help, provide this complete error report to your supplier or license.support@arm.com. - ARMLMD_LICENSE_FILE: unset - LM_LICENSE_FILE: unset - ARM_TOOL_VARIANT: unset - ARM_PRODUCT_PATH: unset - Product location: /opt/arm/developmentstudio-2019.0/sw/mappings - Toolchain location: /opt/arm/developmentstudio-2019.0/sw/ARMCompiler5.06u6/bin - Selected tool variant: productProduct: Arm Development Studio Gold Edition 2019.0Component: ARM Compiler 5.06 update 6 (build 750)Tool: armcc [4d3637]Fatal error: C3903U: Argument 'QSP.no_neon.no_vfp' not permitted for option 'cpu'.Is this because of a feature (QSP) being missing in the professional gold edition of DS-5? We have also tried explicitly setting ARM_TOOL_VARIANT and found no change.
Hi Botmj
we have found this issue, it will be fixed in the next release, 2019.1, soon
thanks
zheng
Ok, thanks, when will the next release come out?
hello Botmj
our new release of ARM DS is ready to download at https://developer.arm.com/tools-and-software/embedded/arm-development-studio/downloads botmj, the problem you mentioned has been fixed
Thanks for informing, I'll test and revert.
Hi Zheng,
I am getting the same error as following with 2019.0-1 DS version downloaded from above link:
Product: Arm Development Studio Evaluation 2019.0-1Component: ARM Compiler 5.06 update 6 (build 750)Tool: armcc [4d3637]Fatal error: C3903U: Argument 'QSP.no_neon.no_vfp' not permitted for option 'cpu'.Warning: C9931W: Your license for feature ds_compiler_eval20190 will expire in 8 daysError: C9580E: QSP is not available with the current toolkit and license. Check that ARM_TOOL_VARIANT is set correctly.Information about this error is available at: ds.arm.com/.../lic81 General licensing information is available at: ds.arm.com/.../ If you need further help, provide this complete error report to your supplier or license.support@arm.com.Product: Arm Development Studio Evaluation 2019.0-1Component: ARM Compiler 5.06 update 6 (build 750)Tool: armcc [4d3637]Fatal error: C3903U: Argument 'QSP.no_neon.no_vfp' not permitted for option 'cpu'.
How to solve this error?
Regards,
jaymin
Hi Botmj,
Did you test with new DS version?
Error solved?
Please let me know. I am facing similar error with new DS version.
This option is not supported by the evaluation license. You will need to use a full product license.
jaymind This feature is not in the evaluation version, please take DS gold version, here is the info of different versions https://developer.arm.com/tools-and-software/embedded/arm-development-studio/editions
Zheng
whether ADS gold and silver edition all support QSP.no_neon.no_vfp ???
章政 This feature must need gold version ???We are ready to use silver version whether support QSP ???
yes, arm compiler 5.06 in the arm development studio support QSP.no_neon.no_vfp
Hi Marcus, it is supported by Silver and higher editions.
Hi @zheng, I tested the DS 2020 latest release, installed, properly set license, but I'm still getting the same issue while building the trustzone component.
Tool: armcc [4d3637] === Compiling tz/cortexA7/MAZAANAA/tzbsp_l2_dump.c ... Error: C9511E: Unable to determine the current toolkit. Check that ARM_TOOL_VARIANT is set correctly. ARM Compiler could not determine the product installation it is part of. You might be able to resolve this by reinstalling the tools, or ensuring that ARM_TOOL_VARIANT and ARM_PRODUCT_PATH are set appropriately. Information about this error is available at: http://ds.arm.com/support/lic86 General licensing information is available at: http://ds.arm.com/support/licensing/ If you need further help, provide this complete error report to your supplier or license.support@arm.com. - ARMLMD_LICENSE_FILE: unset - LM_LICENSE_FILE: unset - ARM_TOOL_VARIANT: unset - ARM_PRODUCT_PATH: unset - Product location: product not found - Toolchain location: /opt/arm/developmentstudio-2020.0/sw/ARMCompiler5.06u6/bin - Selected tool variant: product Product: unknown Component: ARM Compiler 5.06 update 6 (build 750) Tool: armcc [4d3637]
Hi botmj
it seems you have not set your licence properly. you need open the DS IDE one time after the installation, and select the licence as gold or silver, then open the command line, select the default compiler by run select_default_toolchain.bat under C:\Program Files\ARM\Development Studio 2020.0\bin, you can pick armcc, then run 'armcc --cpu list' you can see, I can see the QSP support there
