I have a Terasic DE1-SoC with the implimented Computer system.
Can someone give me a step by step process to run two separate binaries on both A9 cores using baremetal with AMP configuration? One processor should run one binary, and the other should run the other binary.
I'm not sure how to download two separate binaries in DS-5. Also once I release CPU1 from reset, it seems to randomly choose locations to execute, and interferes with cpu0 for some reason.
embeddedesigner said:Can someone
Would's Terasic be the most obvious candidate for that ... ?
Andy Neil,
Terasic is the manufacturer of the pcb board with the Altera-Intel products integrated in them. They do not offer technical support regarding the use of HPS components, only startup designs regarding the FPGA side of things. I have tried via email, and they refer me over to the intel forums.
Any update on this? I am trying to make some test using both cores in Baremetal and I wonder if it can be done.Thank you in advance
