Data abort exception for unaligned access in Cortex A55
I have written a simple assembly code in Cortex A55, which executes in EL3, 64-bit execution state. In the code, the cache and MMU is disabled which means that any memory accessed will be treated as device memory.
There is a bit in SCTLR_EL3.A to disable the fault alignment for unaligned memory accesses. But in spite of that i am observing an exception getting triggered as Synchronous Current EL with SP_EL0”.
                    R X0 00000000201ffed0
     166140 tic ES  (00000000000011c8:f81e401f) O el3t_s:         STUR     xzr,[x0,#-0x1c]
                    EXC [0x000] Synchronous Current EL with SP_EL0
                    ST 00000000201ffeb0 ........ ######## ######## ........    S:00201ffeb0    nGnRnE OSH
                    R ESR_EL3 0000000096000061
                    R FAR_EL3 00000000201ffeb4
                    R CPSR 800003cd
                    R SPSR_EL3 000000008000020c
                    R ELR_EL3 00000000000011c8
Can you please let me know how do i disable this without enabling the MMU ?
Thanks,
Harshit
