In the first blog of this series, I claimed that as a GPU performance metric, triangles per second (aka TPS or triangle rate) is a chocolate teapot — i.e. utterly and completely useless — and talked about the difficulty of getting a consistent definition of the metric. (Without such a definition, you can't compare triangle rate numbers from different vendors.) I also gave some technical background on how GPUs draw triangles. In this installment, I'll talk about how GPU vendors exploit the definition problem to claim enormous triangle rates, while actually telling you nothing about the performance of the GPU. Finally, I'll explain why, even if you were able to measure an honest triangle rate, you wouldn't want to.How to draw a gazillion triangles per secondOK, so you're a struggling GPU vendor who wants to claim "N gazillion triangles per second". It doesn't matter what N is, as long as it's bigger than the competition is claiming. How can you do it? There are a lot of things you can do that aren't actually cheating, but can be counted on to mislead your less sophisticated customers — who will be the only ones asking about triangle rate anyway. The tricks boil down to choosing triangles and drawing conditions that reduce computation and memory traffic to much lower levels than any real application would ever experience. Let's start with the obvious ones:
The result of these shenanigans is that you'll probably be able to cut the work load down to where the only parts of the GPU doing significant work are the setup engine and the culling logic. Of course, the program you'll be running won't draw anything a rational person would want to look at, but who cares? It'll produce a really big TPS number.How to CheatThe fun doesn't stop with the tricks described above — if you're willing to stop pretending you have any scruples, you can go quite a bit further.
There is an extra-warm spot in Engineering Hell for people who do things like this. Sadly, it is well populated; I'm not making these tricks up, and I didn't think of them myself.
So what can you do? I hope it's clear by now that the only way to know what a vendor's claimed triangle rate means is to get hold of the program that produced it, and read every line very carefully including any data files it uses. Unfortunately, the code will be complex and the vendor (probably) more evil-minded than you are, so you may miss something. A safer option is to write your own test program and watch the vendor run it. It isn't enough to specify the geometry, or the number of pixels per triangle, or that you want "transformed, lit, and textured" or (even funnier) "real" triangles; you have to specify absolutely everything, at which point you've effectively written the code. Modern graphics APIs, even lean-and-mean ones like OpenGL ES, provide a great deal of flexibility, and anything you don't specify can and will be used against you.
However, I have some good news! This is not a problem you have to solve. In fact, reading vendors' triangle rate code, or writing your own triangle rate benchmark, would be a complete waste of your time. Even if you had a rigorously defined, carefully monitored, unquestionably honest triangle rate for every GPU you're interested in, you wouldn't want it. That's because even an "honest" triangle rate is utterly and completely useless: a chocolate teapot. Here's why:
What are benchmarks for?Let's remember the goal here. The whole reason for having graphics benchmarks (or any benchmarks) is to give you a way to tell which GPU (or other piece of technology) is going to meet your needs most effectively. You want to know which one will allow you to render the most complex and beautiful games, or run the most sophisticated UI, or excel in whatever other dimension pleases you. If a benchmark doesn't tell you anything about how the GPU will perform on applications you care about, it isn't useful.
As we've seen, how many triangles per second your GPU can render depends on what kind of triangles you ask it to render. And given the sophistication of modern graphics content, you can't really talk about a "typical" triangle, any more than you can benchmark a CPU by asking how long it takes to run a program. Real applications draw a wide range of triangle sizes, using a huge range of shaders. About all you can say about those triangles is that very, very few of them look anything like the kind of triangles people draw when they are measuring triangle rate. So, triangle rate doesn't tell you anything about how fast a GPU will draw the kind of triangles you are actually interested in.
Triangle Rate Considered IrrelevantYou don't have to be a graphics geek to understand this. Here's an analogy: Suppose you decide that it's taking too long to get to work in the morning. You decide to buy a faster car, so you start gathering benchmark data. You discover that, given special tires and a long enough test track, the 993 series Porsche Carrera has a top speed around 170 miles per hour (mph) — respectable, but the McLaren F1 can hit 240mph, a 40% improvement. So, will the McLaren get you to work faster?
I hope it's clear that the top speed of the car is completely irrelevant to the question. That's because the conditions under which you measure top speed have absolutely nothing to do with the conditions under which you drive to work.
The same is true of triangles per second. Different GPU vendors quote different peak triangle rates, and the differences between them can be large; but what the numbers have in common is, they are all completely irrelevant to performance on real-world applications. That's because the conditions under which people measure peak triangle rate bear no resemblance whatever to conditions experienced when the GPU is rendering useful content.
So, you'll have to forgive me if I start to twitch when someone asks me [DRRRRRRRRRRING]
(Sorry, I have to take this — it's our Marketing director, calling from the UK. I'll only be a second.)
"Hi Ian, what's up?" "Tom, I know you hate this question, but we've got a potential customer who wants —" "No! Don't say it. Ian, you promised not to ask again. You know it gives me bad thoughts." "— who wants to know how many triangles per second the Mali T604 —" "Arrrgh! I mean, ummm... Haha! Yes! I mean no. No can do, Ian! We don't use triangles per second any more. We use chocolate teapots!" "Excuse me?" "Chocolate teapots per second. CTPS. It's a much better metric than triangles per second. Haha! We tessellate the Utah teapot into 4000 triangles, so 10,000 CTPS is 40 million triangles per second. We use a modified Blinn-Phong shader with a gloss map, and we add a Fresnel term because chocolate is a dielectric. Did you know that? And we also — " "Listen, Tom, maybe we should talk about this another time — " "Great! Bye!" Click
OK. Deep breath. I am a leaf floating on still water; I am a tree in a silent forest. I am calm.
There! All better. Well, that's enough for today I think. If you'll excuse me, I have to lie down now. Or perhaps — perhaps I'll just make myself a nice cup of tea.
Silliness aside — I'm kind of proud of the Porsche/McLaren thing, but do you have a better way of explaining the uselessness of triangle rate? Or, do you have other favorite ways to lie, cheat, and steal your way to an enormous triangle rate? Let me know...
