Designed for visual computing and using innovative tri-pipe architecture, the ARM® Mali™-T624 GPU delivers significant performance improvements over current Mali graphics processors. The second generation Mali-T600 Graphics Processor Unit (GPU) extends API support to include OpenCL™ Full profile as well as embedded and Microsoft® DirectX®.
Designed for visual computing and using innovative tri-pipe architecture, the ARM® Mali™-T624 GPU Compute solution builds upon a track record for high-quality scalable multicore solutions for 2D and 3D graphics. Key APIs supported include OpenGL® ES 1.1, OpenGL ES 2.0 and OpenGL ES 3.0*, DirectX® 11 and OpenCL™ 1.1.
The Mali-T624 scales from one to four cores, it is a complete embedded graphics and GPU Compute acceleration platform and enables the development of advanced user interfaces, gaming capabilities and GPU Compute applications for a wide range of tomorrow’s consumer devices, from smartphones to tablets, from DTV to portable gaming and beyond.
Mali-T624 pipelines provide true IEEE double-precision floating-point math in hardware for Full Profile, as well as Embedded Profile, OpenCL support. Production-quality software support, via a single driver stack for all multicore configurations, provides simplified application porting, system integration and maintenance. Multicore scheduling and performance scaling is fully handled within the graphics system, with no special considerations required from the application developer.
The Job Manager within Mali-T600 Series GPUs offloads task management from the CPU to the GPU and enables seamless load balancing across active shader cores. Through ARM coherency and interconnect technology, compute tasks can conveniently span the CPU and GPU as well as other available compute resources, accessing data more efficiently during shared processing in a heterogeneous system.
4xFSAA
16xFSAA
OpenCL™ 1.1
Renderscript™
