Embedded and Microcontrollers blog Whitepaper: How automotive body electronics are changing
  • Cortex-M0
  • automotive
  • Embedded
  • Cortex-M
  • NXP
  • Cortex-M4
Eoin McCann
Eoin McCann
September 13, 2017
Body control applications can sometimes be overlooked in favour of application areas which at face value are seeing a greater rate of change, such as advanced driver assistance, safety and electrified powertrains. However, the sheer volume of body domain functions, and the associated high number of microcontrollers used to implement them, means that body applications are of significant importance to semiconductor vendors. In 2016, Strategy Analytics data shows that over 50% of all microcontrollers fitted to light vehicles were used in body domain applications, with over 1.3 billion MCUs fitted.
In the research report below you will learn:
  • Why the volumes involved in body electronics make it a prime opportunity for growing market share in automotive
  • Why a shift is taking place from 8- and 16-bit MCUs to 32-bit processing
  • Key requirements for future body electronics such as security, functional safety and AUTOSAR
Download the Whitepaper
ARM Moves Further Into Automotive with NXPs Launch of S32K Series.pdf
  • Eoin McCann
    Eoin McCann over 8 years ago in reply to Brian Fuller
    Really? You get an error message or something?
  • Brian Fuller
    Brian Fuller over 8 years ago
    Can't seem to access the whitepaper.
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Fidel Makatia
    Fidel Makatia
    • December 4, 2024
