I have an Odroid XU3 board. And i am trying to program the Mali-T628 GPU on this board with OpenCL.
With the devices example that comes with the Mali SDK, I came to understand that there are two GPU devices on the Mali-T628. One device with 4 compute units and another device with 2 compute units. I was able to use these devices separately and found that the device with 2 compute units is slower than the device with 4 compute units. But I could not get them to run in parallel.
I created separate command queues for these devices and enqueued the kernels(assigning double the work for the larger device). Though the two kernels seems to be put in their queues immediately, the second kernels seems to start execution only after the first completes. From the profiling information, it seems that the kernels are getting executed sequentially. Profile information given below. Note the queued time for the second kernel.
Profiling information:
Queued time: 0.334ms
Wait time: 21.751ms
Run time: 12246.8ms
Queued time: 12269.4ms
Wait time: 0.183916ms
Run time: 12494.5ms
Is this sequential execution expected ?
Thanks in advance,--Kiran
Hi Kiran,
Using two separate queues for the two devices is the right way of doing things and is known to work.
Could you please share with us the part of your code where you create the devices and command queues ?
Thanks,
Anthony
Hello Anthony,
Good to know that we can use the devices in parallel.
Code is given below.
I create the opencl context. Then get the platforms and then get the devices. For each device I call a function initOpenCL which creates the opencl program and kernel and ties the commandqueue to the device. I use slightly modified versions of the functions given in Mali SDK.
--Kiran
bool createCommandQueue(cl_context context, cl_command_queue* commandQueue, cl_device_id* device)
cl_int errorNumber = 0;
/* Set up the command queue with the selected device. */
*commandQueue = clCreateCommandQueue(context, *device, CL_QUEUE_PROFILING_ENABLE, &errorNumber);
if (!checkSuccess(errorNumber))
cerr << "Failed to create the OpenCL command queue. " << __FILE__ << ":"<< __LINE__ << endl;
return false;
return true;
int initOpenCL(cl_context& context, cl_device_id& device, cl_command_queue& commandQueue, cl_program& program, cl_kernel& kernel, cl_mem* memoryObjects)
const unsigned int numberOfMemoryObjects = 3;
cl_int errorNumber;
if (!createCommandQueue(context, &commandQueue, &device))
cleanUpOpenCL(context, commandQueue, program, kernel, memoryObjects, numberOfMemoryObjects);
return 1;
} else {
cout<<"Successfully created commandQ"<<endl ;
if (!createProgram(context, device, "assets/matmul.cl", &program))
cerr << "Failed to create OpenCL program." << __FILE__ << ":"<< __LINE__ << endl;
cout<<"Successfully created program"<<endl ;
kernel = clCreateKernel(program, "matmul_simple_loop_switched", &errorNumber);
cerr << "Failed to create OpenCL kernel. " << __FILE__ << ":"<< __LINE__ << endl;
cout<<"Successfully created kernel"<<endl ;
return 0 ;
int main()
cl_uint num_platforms;
cl_platform_id platforms[32];
cl_uint num_devices;
cl_device_id devices[32];
cl_command_queue commandQueue[32] ;
cl_program program[32] ;
cl_kernel kernel[32] ;
cl_context context = 0;
createContext(&context)
clGetPlatformIDs (32, platforms, &num_platforms);
int i, j ;
for(i = 0; i < num_platforms; i++) {
clGetDeviceIDs (platforms[i], CL_DEVICE_TYPE_ALL, sizeof(devices), devices, &num_devices);
for(j = 0; j < num_devices; j++)
initOpenCL(context,devices[j],commandQueue[j],program[j],kernel[j],memoryObjects) ;
So are you suggesting that it is likely to be an error in my code. Have you seen examples of opencl kernels running in parallel on the two devices on the Mali-T628 GPU ?
I can't see anything wrong with the part you pasted, could you please paste he rest of the host code?
I'll try to run it tomorrow.
You can find the code in the link given below.
two_device
I tried my OpenCL code on an Nvidia Titan GPU with two devices and the kernels seem to be running in parallel on that GPU. Profiling information given below.
Queued time: 0.002688ms
Wait time: 0.00464ms
Run time: 107.821ms
Queued time: 0.005056ms
Wait time: 0.121632ms
Run time: 54.1882ms
Your code is roughly doing:
foreach device in devices: enqueue( queue[device], kernel ) foreach device in devices: finish(queue[device])
The problem is you're not flushing the queues therefore the kernels only get sent to the GPU when clFinish is called which is not what you want.
If you add a clFlush after the enqueue then the jobs will get executed in parallel:
foreach device in devices: enqueue( queue[device], kernel ) clFlush( queue[device] ) foreach device in devices: finish(queue[device])
You should then see something like:
Profiling information: Queued time: 0.315959ms Wait time: 14.0343ms Run time: 15394.6ms Profiling information: Queued time: 14.0195ms Wait time: 0.079417ms Run time: 15331.2ms
Run time: 15394.6ms
Run time: 15331.2ms
Hope this helps,
Thanks a ton Anthony. Works fine with the flush.
