for loop not executing
Good Day, i am writing a code for a density based traffic light project using for loops for the density part of the system, but my for loops wont execute. the code is attached below.
  • Rearranged code for better comprehension, sorry for the confusion caused
    #include<reg52.h>
    sbit in1_na=P2^0; //sensor1
    sbit in2_nb=P2^1; //sensor2
    sbit in1_wa=P2^2; //sensor3
    sbit in2_wb=P2^3; //sensor4
    sbit in1_sa=P2^4; //sensor5
    sbit in2_sb=P2^5; //sensor6
    sbit in1_ea=P2^6; //sensor7
    sbit in2_eb=P2^7; //sensor8
    sbit out1_ng=P0^0; //north light green
    sbit out2_ny=P0^1; //north light yellow
    sbit out3_nr=P0^2; //north light red
    sbit out1_wr=P0^3; //west light red
    sbit out2_wy=P0^4; //west light yellow
    sbit out3_wg=P0^5; //west light green
    sbit out1_eg=P1^0; //east light green
    sbit out2_ey=P1^1; //east light yellow
    sbit out3_er=P1^2; //east light red
    sbit out1_sr=P1^3; //south light red
    sbit out2_sy=P1^4; //south light red
    sbit out3_sg=P1^5; //south light green
    unsigned int i,j,k=0,v1=0,w1=0,x1=0,y1=0,z1=0,t1=0;
    void delay_2sec();
    void delay_5sec();
    void delay_12sec();
    void main()
      while(1)
        v1=0;   //clear v1
        w1=0;   //clear w1
        x1=0;   //clear xl
        y1=0;   //clear y1
            if(in1_na==1)     //if sensor1 is blocked
                   v1=1;
           if((in1_na==1)&&(in2_nb==1))  //if sensorl & sensor2 are blocked
                   v1=2;
           if(in1_wa==1)   //if sensor3 is blocked
                   w1=1;
            if((in1_wa==1)&&(in2_wb==1))   //if sensor3 and sensor4 are blocked
                   w1=2;
            if(in1_sa==1)  //if sensor5 is blocked
                   x1=1;
            if((in1_sa==1)&&(in2_sb==1))  //if sensor5 & sensor6 are blocked
                   x1=2;
            if(in1_wa==1)   //if sensor7 is blocked
                   y1=1;
            if((in1_wa==1)&&(in2_wb==1)) //if sensor7 and sensor8 are blocked
                  y1=2;
    out1_wr=1; //led on
    out2_wy=0; //led off
    out3_wg=0; //led off
    out1_sr=1; //led on
    out2_sy=0; //led off
    out3_sg=0; //led off
    out1_eg=0; //led off
    out2_ey=0; //led off
    out3_er=1; //led on
    out1_ng=1; //led on
    out2_ny=0; //led off
    out3_nr=0; //led off
    delay_5sec();  //delay for 5sec
    out3_er=1; //led on
    out1_ng=0; //led off
    out2_ny=1; //led on
    delay_2sec();   //delay for 2sec
    out3_nr=1; //led on
    out1_eg=1; //led on
    out3_er=0; //led off
    out1_sr=1; //led on
    out1_wr=1; //led on
    out2_ey=1; //led on
    out1_sr=1; //led on
    out3_nr=1; //led on
    out3_er=1; //led on
    out1_sr=0; //led off
    out3_sg=1; //led on
    out1_wr=1; //led on
    out2_sy=1; //led on
    out1_wr=1; //led on
    out3_nr=1; //led on
    out3_er=1; //led on
    out1_sr=1; //led on
    out1_wr=0; //led off
    out3_wg=1; //led on
    for(k=0;k<=v1;k++)
    delay_2sec();
    out3_wg=1;
    for(k=0;k<=w1;k++)
    out2_ny=0; //led on
    out3_nr=1; //led off
    out2_sy=0; //led on
    out3_sg=1; //led off
    delay_2sec();
    out1_eg=1; //led off
    out2_ey=1; //led off
    out3_er=0; //led on
    out1_sr=0; //led on
    out2_sy=1; //led off
    out1_ng=0; //led on
    out2_ny=1; //led off
    out1_wr=1; //led off
    out2_wy=1; //led off
    out3_wg=0; //led on
    delay_2sec();
    out1_ng=1;
    /*******************12s delay*****************/
    void delay_12sec()
    for(j=0;j<12;j++)
    for(i=0;i<1000;i++)
    TMOD=0X01;          // SET THE TIMER IN MODE 1 MODE
    TL0=0XFE;           // LOAD THE THO VALUE
    TH0=0XFB;           // LOAD THE TL0 VALUE
    TR0=1;              // START THE TIMER0
    TF0=0;
    while(TF0==0); // WAIT FOR TIMER OVERFLOWS
    TF0=0;              // CLAEAR THE TIMER0 OVER FLOW FLAG
    TR0=0;      //STOP THE TIMER
    /*******************5s delay*****************/
    void delay_5sec()
    for(j=0;j<5;j++)
    for(i=0;i<1000;i++)
    TH0=0XFC;           // LOAD THE TL0 VALUE
    TF0=0;
    /****************** 2s delay ********************/
    void delay_2sec()
    for(j=0;j<2;j++)
    for( i=0;i<1000;i++)
    TMOD=0X01;  //SET THE TIMER0 IN MODE 1 MODE
    TL0=0XFE;  //LOAD THE TH0 VALUE
    TH0=0XFD;  //LOAD THE TL0 VALUE
    TR0=1;     //START THE TIMER0
    TF0=0;
    while(TF0==0); //WAIT FOR TIMER0 OVERFLOWS
    TF0=0;      //CLEAR THE TIMER0 OVER FLOW FLAG
    TR0=0;      // STOP THE TIMER
  • That shows the problem very clearly, even though you're still not pasting the code nicely here.
    You're in the while loop continually checking your inputs, and never come out of that loop to process your outputs.
  • Let me explain the idea of the code:
    i am emulating a density based traffic system for a 4 way traffic junction. the code for the normal operation of a traffic junction works fine.
    where i am having difficulty is the part where i take inputs from one or 2 of the sensor ports and make them 'on' using a for loop for when this condition is meet signifying the lane where those sensor are has a higher density and should be given priority.
    so am i approaching it wrong, or is there a problem with a part of the code. as this is the only problematic part of the code.
    Isn't that amazing
  • We've got past your initial problem. Now it's time for you to put your thinking cap on and consider the most suitable sequence to achieve your final result.
