I am trying to send data through GPRS via SIM300 modem. The logic of my program should be. 1) it should send the data till it receives "dieman" from the server. 2) the modem is such that after every command there is a reply. 3) all the communication takes place serially.
Firstly the GPRS commands as tried in hyperterminal
AT OK AT+CGATT=1 OK AT+CGDCONT=1,"IP","airtelgprs.com" OK AT+CSTT="airtelgprs.com","","" OK AT+CIICR OK AT+CIFSR 212.22.22.22 //EG OF AN IP ADDRESS AT+CIPSTART="TCP",""80"">http://www.google.com","80" OK CONNECT OK AT+CIPSEND >THIS IS THE DATA I WANNA SEND // YOU CAN SEND THE DATA VIA GPRS NOW [CTRL+Z] SEND OK
this is what i want to implement in C in 8052. here OK are the response from the modem.
now i implemented the C version but my code is very inefficient. I could have ignored the response from the modem by simply inserting delays but i want my code such that if the reply from the modem is not "OK" it should transmit the command again.
Also known as Finite State Machines; FSM
And as Finite State Automata; FSA
(Note that Automata is the plural of Automaton so one FSA would be a Finite State Automaton)
