Does anyone know how to open the samples from the text guide, Chapter 16 for W7?
I have already downloaded the emulator, cmake and Visual Studio.
The instructions are somewhat confusing for me on page 448.
trying to get started with the 'Hello Triangle' code.
Hi Lester,
No such issues on my end:
Give it a try with 3.3.0-rc4 (latest available on the site at time of writing) and give a different directory for "Where to build the binaries" is worth doing.
Hth,
Chris
Hello Chris.
Late reply from my part.
I can get CMake to configure and generate with no errors.
But it fails to point to any specific EGL Libraries.
In Visual Studio it generates error code C1083.
Thanks in advance.
Sincerely,
les
Starting with earliest error first, I noticed you're still pointing CMake at a specific sample code, you should instead be pointing it AT THE ROOT! In your case this looks to be E:/OpenGL ES/opengles3-book-master/
Cheers,
Deleted all files and uploaded them again.
It looks like I may have to alter a line somewhere on the CMake list.
It also says to look into build/CmakeFiles/CmakeOutput.log.
Can't find it. Will start again.
As the error states you just need to set EGL_LIBRARY and OPENGLES3_LIBRARY in the CMake window, you've left them as EGL_LIBRARY-NOTFOUND and OPENGLES3_LIBRARY-NOTFOUND respectively.
