Summary
Is OpenCL support for the Mali-T628 (for example as found in the Exynos 5420 SoC on the Arndale Octa board) available? If so, how to set it up?
More details
According to the vendor, OpenCL should be supported, but the Arndale Octa Wiki does not state how this can be achieved.
I am using the latest Linaro developer build and installed Mali drivers that contain OpenCL libraries for Mali T604. According to this guide, the driver actually contains references to the Mali T628. So I tried to create the udev rule as specified, which is supposed to solve a permission problem with /dev/mali0, but I found that there is no /dev/mali0 on my installation at all. So my conclusion is that the driver indeed does not support T628.
When I execute a clinfo utility, clGetDeviceInfo returns CL_OUT_OF_HOST_MEMORY for some device properties. Why can I query the GPU for some characteristics, but does this fail for some others? When running a normal application, the same error appears when trying to create an OpenCL Context.
I was surprised to find this topic, where yoshi seems to have OpenCL working and can run benchmarks on his Arndale Octa board. How is this possible if there is no driver available? Or am I just missing something? I hope that you can help me to also establish a working OpenCL development environment.
Hi Chris,
We create all our kernels first, then we allocate required buffers and then call clEnqueueNDRange. Sometime it fails to create some kernels(some are got created). And sometimes it fails in buffer allocation. It didnt hit clEnqueueNDRange yet.
Thanks,
Veeranna
It's interesting that its not deterministic where it fails. Without a reproducer I'm afraid I'm just guessing at possible causes. Also the driver itself is quite old now, we're currently at r4p0, so it is worth asking them when they plan to provide an up to date version as this could fix it.
Chris
I tried the SGEMM sample from the SDK:
root@arndale-octa:~/Mali_OpenCL_SDK_v1.1.0/samples/sgemm# ./sgemm [PLUGIN INFO] Plugin initializing [PLUGIN DEBUG] './override.instr_config' not found, trying to open the process config file [PLUGIN DEBUG] './sgemm.instr_config' not found, trying to open the default config file [PLUGIN ERROR] Couldn't open default config file './default.instr_config'. [PLUGIN INFO] No configuration file found, attempting to use environment [PLUGIN INFO] CINSTR GENERAL: Output directory set to: . [PLUGIN INFO] No instrumentation features requested. ^C[ 384.380000] Mali<ERROR, BASE_MMU>: kbase_mmu_report_fault_and_kill Unhandled Page fault in AS0 at VA 0x00000000B6F0E100 [ 384.380000] raw fault status 0x820003C3 [ 384.380000] decoded fault status: SLAVE FAULT [ 384.380000] exception type 0xC3: TRANSLATION_FAULT [ 384.380000] access type 0x3: WRITE [ 384.380000] source id 0x8200 [ 384.400000] Mali<ERROR, BASE_JM>: kbase_job_done_slot t6xx: GPU fault 0x43 from job slot 1
The program hangs after the [PLUGIN INFO] messages are printed. When I press ctrl+c, the kernel messages appear, indicating that the GPU run into trouble?
That looks like an integration problem to me, it's worth reporting to Linaro, as I believe that's the kernel you're using?
Hope this helps,
can you give a rough timeline for when octabard Opencl support would be available in a linaro hwpack/filesystem (not necessarily in the main builds) ?
I'm interested in the functional capability - not so much about absolute performance as being able to put a board in front of some people so they can develop with Opencl.
As alternative to octaboard in the shorter term, does anyone know if there is a prebuilt download of the Chromebook/mali image that is described in many steps on the developer site: https://developer.arm.com/graphics/development-platforms/samsung-chromebook
thanks, Raoul
Hi Raoul,
So the Linaro Mali support is available if you look up this thread, but it looks like OpenCL could be broken at the moment. I'd recommend grabbing whatever is available from Linaro or from the post above, test it, and if it doesn't work for you report that to Linaro so it can be fixed. This is downstream of us so I can't give dates or anything, you'd need to talk to them.
As alternative to octaboard in the shorter term, does anyone know if there is a prebuilt download of the Chromebook/mali image that is described in many steps on the mali site at: https://developer.arm.com/graphics/development-platforms/samsung-chromebook
ARM provide the userspace binaries necessary for GLES/CL support on the Chromebook, but we do not have legal approval to release a public BSP image at this time, which is why we wrote the guide for the Chromebook. I don't think the click-through licence on malideveloper.arm.com for the userspace binaries allows redistribution, but as far as I know there is nothing stopping someone from following that guide, and creating an image from that and distributing it, with instructions to just grab the mali blob from the site. So far to my knowledge no-one has done this, but assuming there's nothing in any applicable licences precluding it, feel free to do so!
Finally we are able to run our application on T628. But performance numbers are not good. Do we get any improvement if we move r4p0 driver?
Any other suggestions to improve the GPU performance will be helpful.
Hi Veeranna,
There are a number of performance improvements present in the r4p0 driver not present in previous releases. Keep in mind that OpenCL is not performance portable, so an application optimized for another platform, or otherwise written with another architecture in mind, may not be performant when run on another platform/architecture. The below materials contain advice and detail some of the differences and considerations when moving from desktop to Mali, so let us know if they helps or if you have any further queries and we'll be happy to help.
There is the Developer Guide: Mali-T600 Series GPU OpenCL Developer Guide « Mali Developer Center
There is also the OpenCL faq: http://malideveloper.arm.com/downloads/OpenCL_FAQ.pdf
And the Laplace case study by timhar01 Technical presentation about ARM Mali-T600 GPU and ARM Mali-T700 GPU Compute - YouTube (although I recommend you watch the whole video)
Hi bramv,
I managed to get OpenCL working on the Arndale Octa board. I used the latest Linaro hwpack and file system.
then did:
sudo linaro-media-create --image-file test_image.img --dev arndale-octa --hwpack hwpack_linaro-arndale-octa_20140525-654_armhf_supported.tar.gz --binary linaro-trusty-server-20140522-661.tar.gz
to create an image to make a bootable SD card.
I then copied ahbijeet's compiled kernel files board.dtb, uImage, uInitrd from http://livehopper.com/boot.tar over the existing ones in the boot partition of the SD card.
Using the fbdev version of the userspace drivers. I was able to successfully run the sgemm example from the SDK as root, linking with libmali
Not sure exactly what I did that was different than you..
Simon
I tried again using the rootfs, hwpack and boot files that you provided and can now also compile and run the samples from the Mali SDK!
WIth some more fiddling I also managed to compile and run my own programs. Performance however is way lower than I expected. I modified the clpeak benchmark so that it runs on the Arndale Octa, and get the following resuls:
While I would have expected to measure around 100 GFLOPS for SP compute using float4 vectors. I will have to look into this, but at least I have OpenCL running and that was the goal of this topic after all.
Thanks a lot to all of you for helping me.
Btw,
When creating this OpenCL environment on the Arndale Octa, I kept track of all commands that I executed and used them to write a brief guide on the Insignal Developer forum.
Hi Bramv,
At the risk of beating a dead horse, by my math the peak throughput of the Mali T628 MP6 in the Arndale Octa is:
17 FLOPS * 2 ALUs per core * 6 cores * 0.533Ghz (i think this is the max frequency for this board?) = 108.732 GFLOPS. But, as those cores are distributed across 2 core groups (4+2) simply using the first device available will mean you're only running on 4 cores, so that comes down to 72.488GFLOPS. That's the peak possible throughput of the A pipes, if you were to just keep pumping instructions through it which perfectly exercise all the functional units. In the real world, where kernels tend not to map perfectly to the hardware, tend to include some LS activity, tends to try and load stuff not in the cache, bandwidth is finite etc, it is not expected that you will actually achieve this in real world use cases. Asking for peak flops is the wrong question if you're really interested in peak real world performance.
I am seeing 33.27 and 33.17 SP GFLOPS for float2 and float4 respectively, or 45% of max theoretical peak (this is very good, considering its probably just using the VMUL and VADD units, havent looked into it yet), without looking at the actual code of the benchmark, which seems to indicate your environment has some issue. I will investigate why this benchmark reports almost identical perf numbers for float2 and float4. I also have to state that I've never seen clpeak before and am in no way vouching for its accuracy or usefulness when comparing GPU products.
Hth,
UPDATE: I've taken a look at the kernels and sure enough apart from right at the end they only touch the VMUL and VADD units. The workload is purely vector add and multiply, and absolutely does not touch the scalar or dot units, so you can take that 17 FLOPS down to 8, and our peak realistic performance becomes:
8 FLOPS * 2 ALUs * 4 cores (in one core group, which is 1 CL device) * 0.533 = 34.112 GFLOPS peak realistic performance.
We're seeing 33.27 GFLOPS, which is 97.5% of peak realistic performance, so not too shabby.
Hi Chris, I am glad that you did reply, you bring up some very interesting topics!
For me only one OpenCL platform containing only one device is found and when I request the number of compute units and clock frequency:
cl::Device device device.getInfo<CL_DEVICE_MAX_COMPUTE_UNITS>(); device.getInfo<CL_DEVICE_MAX_CLOCK_FREQUENCY>()
cl::Device device
I get 6 and 600 respectively. So I would assume that I am running on all six cores at 600 Mhz. Is there anything I can do to verify which core group is actually used?
Somewhere else mentioned the following formula for peak floating points performance:
16FP x 2 Vec4 x 6 Clusters x 0.600 GHz = 115.2 GFLOPS
Here the number of flops is 16 instead of 17, so I wonder where those numbers come from. Is there any reference document (by Mali?) that lists all important specs, like the number of FLOPS (including the exact number of vector, scalar and dot units per compute unit?
I ran clpeak on another architecture (Nvidia Tesla K40) and the program indeed measured peak performance (of about 4000 GFLOPS), therefore I assumed that I could also use this benchmark to measure peak performance of this Mali GPU. SInce this clearly doesn't work, I wonder how if I we could come up with some kernel that runs at +/- 100 GFLOPS. What benchmark are you using to measure those 33.27 GFLOPS?
You might be wondering why I am so determined to run the GPU at peak performance, but that is to ultimately be able to directly compare the efficiency of this presumably energy-efficient GPU to more common accelerators like the Nvidia Tesla K40, AMD Firepro W9100 and Intel Xeon Phi.
It must be a typo for them, it's definitely 17 max.
I normally use http://graphics.stanford.edu/~yoel/notes/clInfo.c to quickly sanity check a platform. Will run this on the chromebook to confirm when I get it running again this afternoon.
That's with clPeak, it gives me the numbers I would expect for the work that it's doing, i.e. just vector add and multiply, no scalar, no dot product. We have a kernel which exercises all functional units, but it is obviously synthetic and not representive of a real workload. I cannot stress enough that if you are interested in real world performance, you should move away from these synthetic benchmarks and look at actual data for proper use cases. There are some real-world oriented benchmarks out there already, which already have Mali powered devices in their results.
directly compare the efficiency of this presumably energy-efficient GPU...
Do you have a workload in mind? Does clPeak represent the sort of work you will be doing? If not I'd recommend looking into existing benchmarks/applications which represent the sort of work you will be doing and use that as your basis for comparison, rather than synthetic benchmarks like this one. Will your application run on handhend smartphones/tablets, or is it intended to be run in a compute farm somewhere?
On T628 MP[5-8] there will be 2 core groups, so it should not be possible to see one device with 6 cores, they will be exposes as 2 separate devices. It might be an issue with the benchmark? That does explain where your expectation came from however
UPDATE: Have spoken to someone from the driver team, if you're only seeing one device then it must be an old driver, it's worth asking Insignal what their roadmap is for providing updates. On current drivers you will see 2 devices, one with 4 cores and one with 2.
Just to add to what Chris has said about this, this is indeed what we see with older versions of the driver. As you are seeing, with this version it does return 6 cores, though it really will only run on 4 of them. This particular SoC configures the 6 cores into 2 core-groups, 4 + 2. With the driver version you are using you can only target the 4-core group with CL... it is only later drivers that allow access to both core groups, and then it will be as separate devices so you will need to manually split the work if you want to use all the cores. (Graphics works differently and can automatically spread the workload across the entire GPU).
Hope that helps, Tim
