Suggestion on suitable arm processor
Hi all. Nice to meet you all and glad that I have a chance to join this group=)
Recently, I will do my final year project with the title of "Smart Home Control Using Brain Wave". Yet, I am not really sure on which arm that I should choose><
Could you all give any suggestions to me?
Thanks and best regards,
Seet Ting Ma
  • may i know what language is running bu raspberry pi 2?
    I am still new in arm and are interested in this^^
  • In india some of major problems are there..!! one of is Alcohol addiction. i want to remove such problem from india by using brain technology.
    can you tell me your idea for this project..??
  • thanks for yr replies.
    by the way, i discover that raspberry pi need to equipped with pi face then only it can be used to to control LED, sensors and so on...is it true?
  • my idea is very easy actually...
    I want want to create a smart home that can be control by using brain wave and some motion.
  • Is that compatible if i choose to use LPC 1768?
    From my opinion, since I will use Matlab to process the signal from EEG amplifier, then i just need to send the processed signal to the arm to perform next action like switch on or off the light and etc.
    so what do you all think?
  • No, you do not need any extra hardware, because the GPIO pins are available to you.
    The PiFace you're thinking of may contain relays; these are for turning on/off things that require more power than a LED.
    The only things you need, in order to control LEDs are ...
    1. a LED.
    2. a resistor (I recommend 1K Ohm, that's 1000 Ohm).
    3. two wires.
    One wire connects one end to VCC on the Raspberry Pi, the other end to the resistor.
    The free end on the resistor should be connected to the anode (plus, long pin) of the LED.
    The cathode (minus, short pin) of the LED should be connected to the second wire.
    The second wire's other end connects to a GPIO port of your choice on the Raspberry Pi.
    You should now configure that GPIO pin to output, then you can switch the LED on/off by changing the pin's value.
    The 1K Ohm resistor is chosen, because the light won't blind you, plus it will make sure that the GPIO pin can handle the current going through the LED.
    If selecting a stronger resistor, the LED will become brighter, but be careful; if it's too strong, it might draw too much current for the Raspberry Pi to handle.
    You will need to find out how much current a GPIO pin can sink and calculate the strongest resistor value you can use.
    (The lower resistance, the stronger the resistor is, and more current will flow through the resistor)
    Example if VCC is 3.3V:
    3.3V / 33000 Ohm = 0.0001 Ampere = 100uA. The LED will be completely off, no matter what you do.
    3.3V / 3300 Ohm = 0.001 Ampere = 1mA. If you're lucky, the LED will be lit, but the light will be very weak.
    3.3V / 1000 Ohm = 0.0033 Amperes = 3.3mA. This should be safe for all microcontrollers.
    3.3V / 100 Ohm = 0.033 Amperes = 33mA. This is most likely too strong a resistor; the GPIO pin might get fried after a while.
    The above actually applies to any microcontroller.
  • 1st of all, you decide which signal you going to capture(analog or digital or other) as per my experiment.. i'm capturing analog signal using op-amp(signal conditioning)  after that converting analog to digital(24bit resolution) to microcontroller(farther logic processing).
  • If you're using the Raspberry Pi as bare-metal (eg. no operating system), then you can use the following languages easily:
    C and C++
    Assembler
    This also applies to the CubieBoards.
    If you use Linux on Raspberry Pi (Linux is installed by default as far as I remember), then you have many more languages to choose from; too much to mention here.
    -But for starters, there's D, Ruby, Perl, Bash, Python, etc.
    The same applies to any other board that runs Linux.
