I'm trying to upgrade the Compilation Process followed in my old code which was working with 16-bit keil compiler ,now with 64-bit keil compiler.Following are the steps done below:
Please help me understand where I'm missing the compilation process.
REM COMP_AS.BAT - THIS BATCH FILE WILL BURN AN EEPROM FOR REM THE M840A ACCUSPEED ENCODER. rem ECHO OFF SET PATH=C:\ASPEED\AE\BurnAspd SET TMP=C:\ASPEED\AE\WORKF SET C51LIB=C:\ASPEED\AE\BurnAspd SET C51INC=C:\ASPEED\AE\BurnAspd DEL STARTUP.OBJ A51 STARTUP.A51 timeout.exe 10 DEL RAM.OBJ CX51.exe RAM.C OBJECT(RAM.OBJ) timeout.exe 10 DEL MAIN.OBJ CX51.exe MAIN.C OBJECT(MAIN.OBJ) timeout.exe 10 DEL SRESET.OBJ CX51.exe SRESET.C OBJECT(SRESET.OBJ) timeout.exe 10 DEL IO.OBJ CX51.exe IO.C OBJECT(IO.OBJ) timeout.exe 10 DEL FREQ.OBJ CX51.exe FREQ.C OBJECT(FREQ.OBJ) timeout.exe 10 DEL TIMER1.OBJ CX51.exe TIMER1.C OBJECT(TIMER1.OBJ) timeout.exe 10 DEL BUILD.OBJ CX51.exe BUILD.C OBJECT(BUILD.OBJ) timeout.exe 10 DEL SCAN.OBJ CX51.exe SCAN.C OBJECT(SCAN.OBJ) timeout.exe 10 DEL PE3291.OBJ CX51.exe PE3291.C OBJECT(PE3291.OBJ) timeout.exe 10 DEL XMIT_RAD.OBJ CX51.exe XMIT_RAD.C OBJECT(XMIT_RAD.OBJ) timeout.exe 10 DEL ATOD_LEV.OBJ CX51.exe ATOD_LEV.C OBJECT(ATOD_LEV.OBJ) timeout.exe 10 DEL BCH.OBJ CX51.exe BCH.C OBJECT(BCH.OBJ) timeout.exe 10 DEL EEPRM.OBJ CX51.exe EEPRM.C OBJECT(EEPRM.OBJ) timeout.exe 10 DEL DIAGNOST.OBJ CX51.exe DIAGNOST.C OBJECT(DIAGNOST.OBJ) timeout.exe 10 ECHO. ECHO. ECHO M840A ACCUSPEED CONTROL PROCESSOR ECHO LINKING OBJECT FILES ... timeout.exe 10 BL51 @LK_AS > ERRORMSG.TXT IF ERRORLEVEL 3 GOTO FATAL IF ERRORLEVEL 2 GOTO ERRORS IF ERRORLEVEL 1 GOTO WARNINGS BL51 @LK_AS ECHO. ECHO. ECHO M840A ACCUSPEED CONTROL PROCESSOR ECHO BUILDING FIRMWARE HEX FILE ... timeout.exe 10 OH51 ACUSPD > ERRORMSG.TXT IF ERRORLEVEL 3 GOTO FATAL IF ERRORLEVEL 2 GOTO ERRORS IF ERRORLEVEL 1 GOTO WARNINGS OH51 ACUSPD ECHO. ECHO. CLS ECHO ACUSPD.HEX IS COMPLETE! ECHO 0 > ERRORLVL.TXT ECHO SUCCESSFUL COMPILE! GOTO EXIT REM ************************************************************************* :WARNINGS ECHO THE PROGRAM CONTAINS A WARNING(S) ECHO 1 > ERRORLVL.TXT GOTO EXIT REM ************************************************************************* :ERRORS ECHO THE PROGRAM CONTAINS AN ERROR(S) ECHO 2 > ERRORLVL.TXT GOTO EXIT REM ************************************************************************* :FATAL ECHO THE PROGRAM CONTAINS A FATAL ERROR(S) ECHO 3 > ERRORLVL.TXT GOTO EXIT REM ************************************************************************* :EXIT ECHO. ECHO. CD .. CLS REM **************************** END OF FILE ********************************
Regards,
kaushendra sah
