Hello there,I am developing an application using Network Component Version 7.13.1. The application has a HTTP Server and I am using method POST in a several of html pages to submit my device configurations.Every time that a POST is received by HTTP Server, it calls netCGI_ProcessData(), but I don't know how to find out what form is being submitted.Should I use unique input names in my html pages even in different forms? Or is there any way to work with different forms with same input names?Regards,Murilo
Add a hidden object first to each page, like this:
<input type=hidden value="led" name=pg>
You will then receive the post information in netCGI_ProcessData() as:
"pg=led&..."
The first variable identifies the page from which the POST comes.
Hi Franc, thanks for your reply! That was the solution I've used. It'd be nice having a function supplyed by the library to find it out without depending of web application. I know that it'd make the firmware application dependent of the file names contained in file system. That is, changing a file name would result in unexpected behavior. It'd not be a problem for compact web server.
