Hello team,
I am working on NXP's S32K116 micro (Core - M0+). CPU for this is ARMv6-M. Also I am using IAR compiler. I am having linker issues when I try to call functions from interrupt handlers defined in the Startup_S32K116.s file
Below are some of the handlers where I am calling functions:
EXTERN vPortSVCHandlerEXTERN xPortPendSVHandlerEXTERN xPortSysTickHandlerEXTERN UnusedIntVctrIRQHandler
PUBWEAK SVC_HandlerSECTION .text:CODE:REORDER:NOROOT(1)SVC_HandlerB vPortSVCHandler
PUBWEAK PendSV_HandlerSECTION .text:CODE:REORDER:NOROOT(1)PendSV_HandlerB xPortPendSVHandler
PUBWEAK SysTick_HandlerSECTION .text:CODE:REORDER:NOROOT(1)SysTick_HandlerB xPortSysTickHandler
PUBWEAK DefaultISRSECTION .text:CODE:REORDER:NOROOT(1)DefaultISRB UnusedIntVctrIRQHandler
But I am getting following linker error when I compile the software. Actually it is reporting same issues with all the functions above with different values.
Error[Lp002]: relocation failed: value out of range or illegal: 0x707eKind : R_ARM_THM_JUMP11[0x66]Location: 0x2e12Module: C:\Workspace\GM\PWS\Git_Sandboxes\T6906-86_Smart_FET_Driver\40_implementation\10_Software_Dev\20_ProductionCode\Build\Startup\startup_S32K116.oSection: 15 (.text)Offset: 0x0Target : 0x9e95"UnusedIntVctrIRQHandler"Module: C:\Workspace\GM\PWS\Git_Sandboxes\T6906-86_Smart_FET_Driver\40_implementation\10_Software_Dev\20_ProductionCode\Build\Services\MCUFaultHandler\UnusedIntVectorHandler.oSection: 9 (.text)Offset: 0x1
NOTE: The same function calls I have made from the startup file Interrupt handlers of Core M4 project startup file. CPU for this is ARMv7-M. There I did not see any Linker issues. Please suggest.
This is a Keil forum, IAR questions are not addressed here. Please go to IAR for support
